20 Most Recent
ASUS K53EA1 156Inch Versatile Entertainment Laptop Questions & Answers
Where is the wireless switch on my asus k53e laptop
The switch on most laptops is on either side or at the front. Sometimes it will be a switch to slide, or it might be a button to press.Some laptops may not have a switch at all. In this case there will normally be a set of key strokes that you will have to hit to toggle the wireless ON and OFF.Usually you will have to Press and Hold the FN function key then hit the Key that controls the wireless (F1 thru F12). The correct F1 thru F12 key that toggles the wireless will normally have the wireless icon )))).
How to drag with mouse
Simply left click and hold on the item you wish to drag, then move the mouse to where you want it to be - then release the left mouse button.
Remove internal memory
Click start, all programs, accessories, click command prompt, enter mdsched.exe, this will check your memory.
Fn key unlock
you can try try clean and reseat the kb-cable. If the same problem persists, buy anotther kb.
