20 Most Recent Linksys WRT51AB Wireless Router Questions & Answers
What is 2wire136s wep code?
You can turn the router upside down. If you see a 10 digit number on the router then try that number.If there is no 10 digit number then you will need to check the settings on the router.Try this link to find the WEP key from the router
6/25/2012 12:52:43 PM • Linksys WRT51AB... • Answered on Jun 25, 2012
No any led on when
Check the power supply of your wireless router if it is OK if you know how to used tester check it. If it is OK then checked the software driver of the router if it is properly installed if not re installed it again,make sure to follow the instruction of the manual of router properly.Checked also the settings of other computer you want to link in the wireless router if it is in right settings of wireless connection.
Hope this simple solution could help you to solve your problem. Mam/ Sir don't forget me to rate me up, i really appreciate what grade you have been given to me. Thanks a lot and God Bless.
6/17/2011 4:04:05 PM • Linksys WRT51AB... • Answered on Jun 17, 2011
I cant log on the router limited or no
Try this solution:
1. Click start
2. Go to Control Panel
3. Look for Internet Options and double click
4. On connections tab, look for LAN Settings and click
5. Check the automatically detect settings
6. Click ok
7. Click ok
Please what os did you use? Or are you using a laptop?
Please try to contact me. Because there are a lot of ways to connect to internet. Just tell me more information to solve your problem.
Regards,
Angel
2/6/2011 4:13:39 AM • Linksys WRT51AB... • Answered on Feb 06, 2011
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
2/16/2006 7:45:48 PM • Linksys WRT51AB... • Answered on Feb 16, 2006
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
2/16/2006 7:44:06 PM • Linksys WRT51AB... • Answered on Feb 16, 2006
After changing LAN IP, can not access setup page
If using DHCP, reboot your machine or release and renew the IP on the network card. If using static IP addresses, change the computer's IP address to match the new segment and remove the old default gateway and replace with the new LAN IP.
2/16/2006 7:41:51 PM • Linksys WRT51AB... • Answered on Feb 16, 2006
Static IP on machine, now can't access web sites
Please see the related article on assigning a static IP address behind the router. If you still can not access websites, please try changing the static IP address you're using. For example if you're using the address 192.168.1.2, try 192.168.1.200. If that does not work please try the same static IP address on a different computer to see if it can use the information. If it can please try reinstalling your network card. If that doesn't work please contact Linksys Technical Support.
2/16/2006 7:41:04 PM • Linksys WRT51AB... • Answered on Feb 16, 2006
Finding the MAC Address of a Macintosh
Please follow the instructions which fits the Mac OS that is being run: OSX 1. Click on the Apple menu and select the System Preferences option. 2. In the "System Preferences" window, Select Network. 3. When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu. 4. Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it. OS9 and below 1. Click on the Apple menu option. 2. Go to the Utilities folder 3. Open the program called Apple System Profiler 4. Select the System Profile tab 5. Under Network Overview > Appletalk> 6. Once there you will find the Hardware address, this is the MAC Address, make note of it.
2/16/2006 7:40:06 PM • Linksys WRT51AB... • Answered on Feb 16, 2006
My Linksys WRT54G router is dropping the signal
Very old router. I suspect a failure. I recommend you check out this website to see if there is any hope for it. Linksys WRT54G stuck in self diagnostic mode lol
2/4/2018 3:35:53 AM • Linksys WRT... • Answered on Feb 04, 2018
How Do I Make the Linksys WRT160n Wireless-N Only
Hello, Sit at your computer and open up IE browser. After this has opened up, go up to the url bar and erase anything there and when this is blank, type in http://192.168.1.1 then hit the enter key. The router should now pop up a login menu close to the middle of your monitor. The default password for Linksys routers is ADMIN leave the user name blank and just enter the password ADMIN This then will open up the routers main menus and at the top of the tabs look for the tab named "wireless" click on this tab and look this menu over and you should find the box to check or uncheck to accomplish what you want done. Good luck. By the way, while your in the routers menu "Change the Default Password" to something that you have to write down! leaving the password set the the factory default is a huge mistake. Like leaving all your windows and doors open going on a long vacation! Got it? Dennis
8/26/2017 2:47:55 AM • Linksys WRT... • Answered on Aug 26, 2017
Linksys WRT300N router flashing all lights
On the back of the router you will see what looks like a pin hole, turn the router on and use a paperclip to push into the hole(it's a reset button) and keep it pushed in till the router cycles off then on again, it resets the router to default. Hope this helps.
7/2/2017 11:05:55 AM • Linksys WRT... • Answered on Jul 02, 2017
How do I find network key for wrt120n router
Every router I have ever seen allows you to reset the configuration to factory default - but not allow you to retrieve a forgotten password and maintain your settings at the same time. This is often referred to a "factory" or "hard" reset. When you initiate a factory / hard reset, typically by pressing & holding a button on the router - or behind an opening in the router case - all the changes you've made to it will be returned to the factory default. Wifi becomes "open" with no password (on most devices), the login username / password also go back to default settings (common ones are: admin / admin, admin / password, <blank> / admin, <blank / password, etc.). Consult your router's set up guide or online documentation to learn what the factory / hard reset procedure and the default settings. Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security or network key (use a mix of numbers, letters, symbols etc.). I suggest recording all these settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it. Good luck!
10/17/2014 8:50:54 PM • Linksys WRT... • Answered on Oct 17, 2014
Lost cd for wrt120n
http://downloads.linksys.com/downloads/setupwizard/WRT120N_CD_1.0.01_Windows.zip
8/14/2014 3:55:09 PM • Linksys WRT... • Answered on Aug 14, 2014
2answers
They keep saying i am keying in the wrong wireless password. Is this the router password or am i suppose to find another one. please help
My Linksys wireless router uses a different password to setup a wireless connection with the SSID (wireless account name) than the password for logging into the router for administrative purposes. So I suspect you need a different password. However, without knowing which make/model of router you have, I can't help you identify where to find the information for your wireless setup. Please add a comment with your router information for additional assistance. I hope this helps. Cindy Wells
6/20/2014 9:10:32 PM • Linksys WRT... • Answered on Jun 20, 2014
After setting up my linksys router to ATT DSL and verifying, my iphone won't connect to the wireless network
Select the channel of the wireless network to 1. This will start working. Please follow the link. Basic Wireless Settings
6/19/2014 3:07:43 PM • Linksys WRT... • Answered on Jun 19, 2014
Pin wtr54g linksys
Its on the back of the router.
6/19/2014 2:43:29 PM • Linksys WRT... • Answered on Jun 19, 2014
Logging in to E1000
Username = balank password ADMIN
6/19/2014 2:28:47 PM • Linksys WRT... • Answered on Jun 19, 2014
How do I change the password on my Linlsys 192.168.1.1 router?
You can login to the router page with ip address 192.168.1.1 Login to the router with using the admin password write nothing in the username You can change the admin password on the last page Administration It must be under router password. http://ui.linksys.com/files/WRT110/1.0.04/AdminManage.htm
6/19/2014 2:28:14 PM • Linksys WRT... • Answered on Jun 19, 2014
Can not connect to beini router interface
Suggest to try other settings like 192.168.1.1 and 192.168.0.1
2/28/2014 5:09:37 AM • Linksys WRT... • Answered on Feb 28, 2014
Windows security center
If this is your router and you've forgotten the username or password we suggest that the router be reset and then setup with a new username and password. Default username and password Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router. Username: Admin or Administrator Password: <Blank>, try just pressing enter or try "admin" as the password as well. If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com Sometimes when attempting to visit a secure website on your Windows computer, you will receive a message about a security certificate error. You will have the option of whether to continue to the site. Secure websites, such as an online bank or retail store, use security certificates so your browser knows that any financial or personal information you enter on the website will go the correct place securely. Every error message does not necessarily indicate a security problem on the website. Check your computer's date and time. If they are incorrect, you will receive security certificate errors. Click on the time in your taskbar, and set the correct time in the pop-up window. Refresh the website where you received the error message. If you receive a security certificate error message again, the problem lies with the website's security certificate. Click the icon that looks like a padlock next to your browser's address bar. Read the information in the window. This will detail who owns the website, the site's verification status and any known information about the website's trustworthiness. Compare this to what you know about the site you were attempting to visit. Click "View Certificates, then "Install Certificates." Click "Yes" at the security warning to install the certificate for the website.
5/24/2013 5:34:50 AM • Linksys WRT... • Answered on May 24, 2013
Linksys WRT51AB Wireless Router Logo
11 questions posted
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
WRT Linksys
  • WRT Linksys
Most Popular Question
after changing lan ip not access setup
  • Computers & Internet
