20 Most Recent Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers Questions & Answers
Logitech X-530 speaker set plugged in as per
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
8/9/2017 12:04:56 AM • Logitech X-530... • Answered on Aug 09, 2017
My computer won't recognise all five speakers
I believe you need to go into audio settings via control panel and change two channel desktop speakers to five channel in the drop down menus.there is usually a test scenario for 5 channel that then pulses sound through each speaker separately to ensure your setup us correctly working .
2/22/2015 4:29:56 AM • Logitech X-530... • Answered on Feb 22, 2015
Logitech X-530 subwoofer stopped giving power to
check the drivers click stat control panel administation tools computer management deivice manager scroll to sound video and game controllers could be a yellow question exclamation mark? ! or a red X right click to re-install drivers click start control panel sounds and audio volume advanced speakers make sure you have selected the correct speakers also audio you will find 3 drop down lists make sure you have the correct settings there if you dont have a motherboard disk you will need to download the sound drivers check the leads attached to the rear of the input plugs make sure the connection is good or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems also if you had to hit the subwoofer to get it to turn on check all power leads attached the to and around the subwooferhope this helps
8/4/2011 2:05:01 AM • Logitech X-530... • Answered on Aug 04, 2011
How do i hookup my speakers to my tv
Computer speak usually have a 3.5" headphone plug (just like a pair of headphones). This plug is not native to a TV, they instead usually use RCA plugs (red and white with a solid center post and metal 'sleeve' which makes the connection) these are the most common audio out format for most TVs. You can go to radio shack and buy a 3.5" headphone to RCA adapter which is just a short cable with a female 3.5" plug at one end and two RCA plugs at the other (red and white). This is pretty cheap ~$5 and should get you up and running. You will be going from the label Audio Out ports on your tv through the adapter cable and into your PC speakers.
3/12/2011 3:24:11 PM • Logitech X-530... • Answered on Mar 12, 2011
When I'm not playing anything
cord prolly or maby the "puter"s just how my little brother says it sound card is dead
1/17/2011 4:56:51 AM • Logitech X-530... • Answered on Jan 17, 2011
tip
Fixya.com
x-530 front center speaker will not play
How do i hook up my surround sound
CHANGE SPEAKERS OPTION TO 5.1 IN REALTEK HD AUDIO MAGER SETTINGS IN CONTROLPANEL
3/19/2010 3:14:24 AM • Logitech X-530... • Answered on Mar 19, 2010
No sound from speakers after disconect
start up cd redo if not go to website for download and if not go to your computer makers website for a possible patch
1/18/2010 8:11:27 AM • Logitech X-530... • Answered on Jan 18, 2010
No sound
Hello.....
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....and no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots.....all the best....
12/18/2009 7:11:31 AM • Logitech X-530... • Answered on Dec 18, 2009
I have dell computer and i bought the logitech
take a look at this site might of some help to you?
http://www.logitech.com/index.cfm/support_downloads/&cl=gb,en
if not get back to me with the model number
3/7/2009 6:47:08 PM • Logitech X-530... • Answered on Mar 07, 2009
No instructions
It should be pluged into the box that came with your tv
1/28/2009 7:58:40 AM • Logitech X-530... • Answered on Jan 28, 2009
Need wiring diagram schmatics for Logitech z560
Hello I need to wiring order of this coupling. 20220820_231454-y4lbf2gajxyg1e3idvatmg4t-d-0.jpg
8/20/2022 9:31:46 PM • Logitech Audio... • Answered on Aug 20, 2022
Leftt speaker not working after new GPU
well doing that new GPU Card now has new GPU HDMIL sound channels so in sound setting change outputs to z323 not told you how the z323 wired to the PC. mine uses, FIBER optics. and never fails. the only way to lost LEFT size only is jacks not fully seated (baring hard failures , of the 323) mine is 900 series, and does fiber. (no hum fiber is king) yours has no such things. you are using RCA jack into the speaker right? NO PC told at all. mine has a custom soundcard, and can do it all, you name it, ALL. the problem is posting not tell at al what PC this is of endless vast. there are. desktops can do it all. laptops not. back of the sub has 2 RCA jacks aux input.both must be good and working back to the PC sound card. the sound card must be set up correcty and the silly (no GPU card told) card, must be output all turned off on hdmi. that is all I can do blind , I can not see what you own or what is connected or not. sorry
7/23/2022 10:32:47 AM • Logitech Audio... • Answered on Jul 23, 2022
How to connect my Logitech subwoofer to my aiwa hifi
The sub woofer is active and should not be connected to amp.
3/30/2022 4:46:48 PM • Logitech Audio... • Answered on Mar 30, 2022
Good Day...I had a question about my Logitech Z313 speaker wires
I wonder what the question was ..................... ..
11/1/2021 4:05:03 PM • Logitech Audio... • Answered on Nov 01, 2021
Popular Tags
18 questions posted
Top Logitech Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
logitech x 530 speaker set plugged in as
  • Audio Players & Recorders
