20 Most Recent Logitech SoundMan X2 Computer Speakers Questions & Answers
0answers
Drivers
the device comes with the drivers inbuild or in other media if still you are having the problem go the company home page and click on the supprt link
6/4/2014 7:54:55 AM • Logitech... • Answered on Jun 04, 2014
0answers
Speakers not working
Hi , have you installed your drivers for your soundcard you plugged the speakers into? if you have then it could be that the speakers are faulty and you would have to return them.
thanks
12/29/2009 11:01:01 PM • Logitech... • Answered on Dec 29, 2009
2answers
Only two of my speakers work when i unplug them
check all connections, the volume and the manual again. if problem persist and its still under warranty, use it
10/18/2009 1:49:11 PM • Logitech... • Answered on Oct 18, 2009
Logitech speaker problem
Verify that the audio lead is connected to the correct line out on the computer. Check the sliders in the windows volume control are correct and mute is unticked. Try plugging some headphones into the computer to hear if the PC is actually producing an output.
2/13/2009 10:41:00 AM • Logitech... • Answered on Feb 13, 2009
Onboard Sound Problem
No you will run into alot of problems and you will destroy *********** board.My advice is that you get a different set of speakers that have a pin with suited size for your sound card.
the problem is that the pin of your current speakers is too long for the jack and as a result only contacts for one speaker are fully connected.
Your sound card has no problem,but if you realy want these speakers just buy another sound card and install it and hopefully it will work.
DONT REMOVE YOUR SOUND PORT
it is very risky
3/14/2008 11:56:10 PM • Logitech... • Answered on Mar 14, 2008
I have the logitech docking speaker s-0329A how can i get my iphone 4 to work on it as when i put it on it says it does not support it and can i use an android phone on it through the headphone jack?
The Aux connection should work for either an iphone or android phone. That would be a good test to see if the speaker is still working. The top mounted iphone/ipod connecter can collect dirt and lint that will cause the proper connections to be made. Try cleaning these.
3/12/2023 5:39:30 PM • Logitech Audio... • Answered on Mar 12, 2023
Logitech x-540 speakers worked great with my old laptop but now I have an ASUS laptop and the light comes on on the volume controller but I get no sound and everything is hooked up correctly
Here's a link to the manual. https://www.logitech.com/assets/35723/setup-installation-guide.pdf This is important: 3. A. If you have a PC and a: • 6, 7 or 8 channel (5.1, 6.1 or 7.1) sound card: Connect all 3 colored plugs from the audio input cable to the color-coded jacks on the sound card. 1. If jacks on your soundcard are not color coded, plug the audio input as follows: • green to front L/R (or #1) • black to rear L/R (or #2) • orange to center / sub (or #3) • 4-channel sound card: Connect the green plug from the audio input cable to your sound card's front jack and the black plug to your sound card's rear jack. Do not use the orange plug. • 2-channel sound card: Connect the green plug from the audio input cable to the "line out" jack on your sound card. Do not use the black or orange plugs.
3/12/2023 5:30:36 PM • Logitech Audio... • Answered on Mar 12, 2023
How can we dismantle Logitech Laptop Speaker Z205?
If you try to open these speakers they will never work properly again. There are no screws. All the joints are stapled and glued.
3/12/2023 5:23:28 PM • Logitech Audio... • Answered on Mar 12, 2023
My logitech z523 the sound is so low and the volume knob doesnt adjust and even the led is on or the bass work
What are you connecting the speakers to?
3/12/2023 5:19:00 PM • Logitech Audio... • Answered on Mar 12, 2023
CAN I LISTEN TO MUSIC ON MY LOGITECH DEVICE
If its a speaker, YES.
3/12/2023 5:18:04 PM • Logitech Audio... • Answered on Mar 12, 2023
What is dc5v_1.5a on back of logitech speakers and what do you put in the hole
This is for a fuse. DC volts - 1.5 amps. There should be a screw on cap that retains the fuse. These are common fuses and available at most electronic stores.
3/12/2023 5:17:28 PM • Logitech Audio... • Answered on Mar 12, 2023
How can I bypass the control panel on a Logitech G51 and hook it up to my home stereo?
You can't. The control console is integrated into the system. This is a gaming speaker system meant to connect to a computer or game console.
3/12/2023 5:15:28 PM • Logitech Audio... • Answered on Mar 12, 2023
Can the logitech speaker connect to an I PHONE?
What model Logitech speaker? What model iphone?
3/12/2023 5:05:49 PM • Logitech Audio... • Answered on Mar 12, 2023
Need wiring diagram schmatics for Logitech z560
Hello I need to wiring order of this coupling. 20220820_231454-y4lbf2gajxyg1e3idvatmg4t-d-0.jpg
3/12/2023 5:02:35 PM • Logitech Audio... • Answered on Mar 12, 2023
Logitech SoundMan X2 Computer Speakers Logo
10 questions posted
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
drivers
  • Audio Players & Recorders
