20 Most Recent
ViewSonic TPCV1250S (TPCV1250S0103) Tablet PC Questions & Answers
1250S Display problem
It sounds like the system is trying to reduce power consumption to save battery life. Check your power settings in the control panel and set them to Max Performance to see if it stops doing it. If it does, you know that was the reason. If it doesn't let us know.
Mike Vail
12/3/2013 4:09:42 PM •
ViewSonic...
Answered
on Dec 03, 2013
Viewsonic Tablet PC keyboard issue.
may be the best solution for this problem is consult your hardware manufacturer and ask him to replace the motherboard, if the pc is under warranty they will replace it for free of cost.
4/6/2007 3:24:11 PM •
ViewSonic...
Answered
on Apr 06, 2007
Need operating system for my viewsonic g tablet 300-2.2
Angela,
Your Viewsonic (apparently) used: Android OS 2.2 and that is quite old!
(Almost always), a Android device needs to be OPERATIONAL before it can be updated. It MUST also be able to 'communicate' to receive the updated OS...
Now your VS (apparently) HAS a external SD Card slot, so you MAY be able to copy the new Android OS to that card then maybe you can load from there ~ BUT, your Tablet MUST be operational to do it!
Anthony
7/20/2020 7:57:08 AM •
ViewSonic...
Answered
on Jul 20, 2020
Trying to pair my apple bluetooth keyboard with viewsonic 7 tablet using easy connect
Sorry to hear/read this really.
One thing you've got to know and as a matter of fact acquaint yourself with is this-
Original Apple OS devices, gadgets and equipments DO NOT readily pair or connect with Android OS based devices, gadgets and equipments.
With time, maybe someone can find a way round to resolve this impasse but at the time, its best you save yourself all the aggravations.
Make use of your maplin keyboard instead.
10/6/2017 12:25:34 PM •
ViewSonic...
Answered
on Oct 06, 2017
My tablet wont stay on
It may be due to an energy saving scheme that turns the screen off after 30 seconds, 1 minute, etc of inactivity. Enter setup or settings and increase that time delay to a longer duration.
2/13/2014 3:04:50 AM •
ViewSonic...
Answered
on Feb 13, 2014
Jujitsu st series 4110
The restore partition maybe corrupted. You will need a USB DVD/CD Drive and a Windows XP professional CD. The key should be on the back of the tablet. You will need to download the drivers from the fujitsu site and install them manually.
1/31/2014 2:32:52 AM •
ViewSonic...
Answered
on Jan 31, 2014
Warranty check
Most of the tablets have a reset swithch. If there is not important data, you may try resetting the device.It may be a good idea to reflash the device with its original software.
10/25/2013 12:58:31 PM •
ViewSonic...
Answered
on Oct 25, 2013
BOUGHT A TV I N THE USA BROUGHT TO SWEDEN I CAN
I don't know a whole lot about TV's but I don't think TV's purchased in the USA will work in Sweden unless they were designed specifically for overseas use. In North America we use a system called NTSC and I believe that in Sweden you use PAL. If the TV has the ability to change the setting with a switch you should set it to PAL.
I assume you are running it off of a step-down transformer to cut the voltage (if you don't want it to blow). In North America TV sets are designed for 110 volts. Don't you have 220 there?
You may also have to change the hertz rate to the proper rate there too I believe (forget what it is -- 50 to 60 or vice versa. You may have to call up a technician there ask, or somebody on this site might know). Some TV's simply have a switch on the back that will enable you to do this if they have been designed for both North American and European use.
5/12/2010 7:24:19 AM •
ViewSonic...
Answered
on May 12, 2010
