20 Most Recent Logitech Z-340 Computer Speakers Questions & Answers
Need driver for Logitech Z-340 speaker system.
Sounds like the Subwoofer is blown. Unless you are handy with this stuff, you're outta luck unless you can find someone with the expertise to replace the blown speaker inside. This is not an easy job. If you are up for it you can follow the previously described method for opening it & removing the blown speaker. A suitable replacement can be found at http://www.rpelectronics.com/d03-0004-4-speaker-paper-cone-4-ohm.html Note that it will need to be mounted differently than the original which is mounted on the rear of the panel. The replacement must be mounted on the front. It will need some sort of gasket (foam tape or something) between it & the panel. No soldering is required as push on connectors are used. Connect it up after installation and reassemble the unit.Be aware that there is a possibility that the sub's amp is blown, in which case replacing the speaker is of no use. It would be good if you had some sort of speaker to connect to the terminals once you get the unit open and check that the amp is putting out before ordering a replacement speaker. Good luck!
11/2/2014 12:43:54 PM • Logitech Z-340... • Answered on Nov 02, 2014
0answers
0answers
0answers
Can not get subwoofer z-340 to work with i3
Ensure it is connected according to the manual and plugged into a wall outlet for power. The small speakers might work just being plugged into the computer but the subwoofer requires a much higher voltage to run.
9/30/2013 3:07:54 PM • Logitech Z-340... • Answered on Sep 30, 2013
0answers
0answers
2answers
Cuts in between on higher volumes & higher bass levels
Sounds like the subwoofer speaker is broken. Opening the subwoofer is difficult, and frankly the effort is not worth it, as the quality of this system is very poor.
4/14/2013 3:16:48 AM • Logitech Z-340... • Answered on Apr 14, 2013
Logitech Z-340. I need access to the volume pot in
You need to pop off the grille on the front of the speaker. It's glued to the front. I just used a flat head screwdriver and worked it evenly around to slowly slide it off. Then, unscrew the 4 phillips screws to get to the inside.
4/12/2013 10:53:55 AM • Logitech Z-340... • Answered on Apr 12, 2013
2answers
One of the speakers on my z 354 system not working
could be that the side thats not working has a bad wire, or that something isnt plugged in completly, that is, not inserted fully
10/23/2012 6:10:51 AM • Logitech Z-340... • Answered on Oct 23, 2012
I've plugged in my speakers and the woofer but
Try to check for sound manager to check balance is on for both sides (left right) and wave balance is normal value. To call master volume just duble click system tray volume icon (next to clock) and check it.
11/2/2011 1:40:09 AM • Logitech Z-340... • Answered on Nov 02, 2011
0answers
Logitech Z-340 Computer Speakers Logo
46 questions posted
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
one speakers z 354 system not working
  • Audio Players & Recorders
