20 Most Recent Logitech X-230 Computer Speakers Questions & Answers
0answers
My computer just stopped recognizing my headset,
you need to re-install headset drivers
1/15/2018 7:05:26 PM • Logitech X-230... • Answered on Jan 15, 2018
No sound at all, but power on. Should I replace the phone jack?
Hi Hermann , This is a typical issue with Logitech speakers . You need to bring them back to the the dealer and get an exchange set for free replacement onder warranty . If the warranty has expired , you will need to solve the problem by testing the cables or the printcircuit inside the sub , BUT first connect your head phones or another speakers set to the correct output of your computer's soundcard to verify if the issue actually commes from the speakers . If the test is negative , the issue is to be found in the soundcard and you will need to replace it . Best regards .
5/13/2014 10:35:09 AM • Logitech X-230... • Answered on May 13, 2014
0answers
My right speaker does not work, but left does
tell me how to connect vose speakers to my desktop computor
12/15/2012 7:48:23 AM • Logitech X-230... • Answered on Dec 15, 2012
Broken green pin on logitech x230 can this be replaced
if the green pin is what plugs into your computer, a traditional, headphone 1/8th inch headphone jack, it can be replaced, however there is some soldering involved. Radio shack sells the replaceable ends for just a couple dollars. the only problem is knowing which wires to connect to which points on the new end. i would have to see the wire with the insulation stripped off to be able to tell you which are which
10/19/2012 12:51:08 AM • Logitech X-230... • Answered on Oct 19, 2012
Hello, My logitech x-230 2.1 speaker system is not producing any sound. The power light comes on but no sound at all comes from any speaker. Also, it is not the computers fault because I have used it
If there is an ON/OFF switch at the back of your 2.1 speakers, then switch it on. Or is the VOLUME control set at 0? Turn it up a bit.Or, are the left & right speakers properly hooked to the subwoofer unit?Please check.
7/15/2012 5:12:57 AM • Logitech X-230... • Answered on Jul 15, 2012
0answers
0answers
Logitech X-230 Computer Speakers Logo
147 questions posted
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
broken green pin logitech x230 replaced
  • Audio Players & Recorders
