20 Most Recent
GE GFWN1100LWW Washer Questions & Answers
Cycle pauses after about 6 minutes. It doesn't
From what I just read if the same model sounds like the motor sensor could be bad It says it should read around 118 ohms at the two yellow wires when disconnected at the board.
Not sure if the motor will have to be replaced if the sensor is bad
the inverter can also be the problem
Google GE front load washer won't spin or tumble for more
My GE Front loading washer has a red lock light
On the GE GFWN1100LWW the Lock light indicates that the Child Lock (Panel Lock) is enabled. Press and hold the Lock touch pad for 3+ seconds. The light will go out. (Note: if you hold that button for too long, the lock will disengage and then reengage.)
The lock is useful to avoid having someone change the settings or start the washer when they shouldn't. (For example, you don't want to start or change the cycle settings on the washer while cleaning the control panel's surface.)
I hope this helps.
