20 Most Recent Canon iPF610 InkJet Plotter Printer Questions & Answers
03800500-2F2F/03800500-2F30 Head management sensor error
0014-0999
The head management sensor detected an ink discharge error.
A sensor sensitivity error was detected during head management sensor position adjustment.
Print head, head management sensor, or main controller PCB
1) Replace the print head.
2) Visual check
Remove foreign substances from the head management sensor if any.
3) Replace the head management sensor.
4) Cable continuity check
If continuity of the cable between the head management sensor and the main controller PCB is abnormal, replace
the cable.
5) Replace the main controller PCB
Canon iPF610... | Answered on Sep 10, 2018
http://www.copytechnet.com/forums/canon/66306-ipf610-e196-404e.html
Seems you have an error with the EEPROM, follow the instructions there.
Canon iPF610... | Answered on Mar 20, 2018
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Canon iPF610... | Answered on Jan 28, 2013
RTFM. Page 34 refers
Setting The Display Language - Canon iR2020 Facsimile ...
www.manualslib.com > ... > iR2020 Series > Facsimile manual
Canon iR2020 Manual Online: Setting The Display Language. If you want to switch the Display Language, select the language you want under DISPLAY ...
VIDEOS as well
https://www.google.com/search?q=ir+2020+change+language
Canon Office... | Answered 2 days ago
A Fan issue
www.copytechnet.com > ... > Canon
Feb 2, 2010 - my cannon ir 400machine showing e803,e805.plz help me ... For E805 normally it will follow by a few number behind the code that represent ... full e805 code information, as in the subcode for the error E805-xxxx, which will ... Error Code Canon ir 3300, 803 Error code. - Page 2
Mar. 7, 2013
e 804 error - Copytechnet
Sep. 20, 2011
More results from www.copytechnet.com
IR 400 MACHINE ERROR CODE IS E803-000 - canon - www ...
www.oasq.com > ... > Copier Technical Discussion > canon
Sep 11, 2012 - 2 posts - ‎2 authors
IR 400 MACHINE ERROR CODE IS E803-000--Canon imageRUNNER 400S ... E 803 Codes are Coming IN Cannon IR 400 Copier Machines.
Canon Office... | Answered on Sep 15, 2020
In canon printers the most common error code is B200. You'll learn in this article how to resolve canon printer error b200 by self.
The Canon Printer Error Code B200 on the canon printers means that the voltage of the print head or the heat of the printhead is not usual. In certain situations, the b200 error can also result in damage to the print head and being unable to use it, or a problem with the cartridges.
The Canon printers come in two or 4 + cartridges. If you have Four or more cartridges on your printer, you need to follow the instructions below. If you have a two-cartridge printer, skip to the section below.
Step 1: Extract all cartridges.
Step 2: Extract the printhead.
Step 3: The print head is reinstalled.
Step 4: Bring the cartridges back in.
Step 5: Continue Blog - Canon Printer Error B200
It normally stops if you don't install the ink cartridges correctly. When the failure strick on your printer, it will not allow you to continue with the printing assembly. This error can even make the printing process quiet and stable. If you want to experience a hassle-free printing, then you should Resolve the Canon Printer Error Code 1660. First check the main reasons that cause:-
1.Inaccurate fitting of the ink cartridges.
2. Misplacement of the ink cartridges.
3. Cracked or closed ink cartridges.
4. If the print device is not possible to recognize the ink tank then you may view Canon Support Code 1660
Full Blog - Canon Support Code 1660
Canon Office... | Answered on Sep 09, 2020
Put your fingers in there, pinch the paper with two fingers, lift and move hand towards your body.
https://www.google.com/search?q=IR1018.+How+can+I+empty+output+tray
Canon Office... | Answered on Sep 07, 2020
  1. Take a bowl with warm water and add some soapy material.
  2. Open the ink cartridge compartment.
  3. wait for ink cartridges and disconnect the printers power cord.
  4. Look balck rubber frame under the ink cartridge.
  5. pull the rubber frame out of the printer and remove ink absorber pads.
  6. clean the pads in the bowl.
Canon Office... | Answered on Sep 04, 2020
The Canon Printer Error Code 1401 occurs when the printer machine is not able to recognize one or all the cartridges installed in the machine. These errors show up in the form of messages such as "Fine cartridge isn't installed" for 1401 or fine cartridge isn't installed in a proper manner for 1687 message.Jan 7, 2019
www.printerstechnicalsupport.com > how-to-fix-canon-printer-error-cod...
How to Fix Canon Printer Error Code 1401 ' Printer Technical ...
Canon Office... | Answered on Sep 01, 2020
If the message is "Ink Absorber Full", then the problem is hardware. For most ink jet printers, this means that the unit has reached it's end of life based on the number of print head cleaning cycles/pages printed. If your printer is under warranty (1 year), contact Canon.
To resolve the problem, you would need to disassemble the printer (carefully). Keep plenty of paper towels handy; the job will be messy. The ink pads are usually below where the ink cartridges go during a cleaning cycle. When you reach the rubber pads that hold the waste ink, rinse them until the water runs clear. Dry the pads well. Wipe any remaining ink out of the compartments where the pads were. Reassemble the printer. Now, you can try one of the online reset procedures. I have no idea which ones will work with your Pixma MG3200.
If you do not clean the ink absorbers first, then you will likely get excess ink on your documents and photos. Then additional ink may drip out of the printer.
I hope this helps.
Canon Office... | Answered on Aug 31, 2020
TO ANYONE READING THIS...I nearly took a hammer and smashed my Canon LIDE 110 Scanner cause I was so mad that it gave me this stupid error (5,202,52) no matter where I was connecting it and I thought it was done...
THEN I just took another USB Cable (Like I have around 10 different USB Cables) ...AND IT WORKED! Try several USB cables before you give up on it...also don't start messing around with drivers and stuff, you could end up screwing up your system like I did...
I hope this helps someone out there in the future with error 5,202,52 or 5,202,54, etc.
Try at least 4-5 different USB cables before anything else..
(If you want to know, I successfully used the USB cable with one of the fat black circle things on it (I think its for power or something), not just a straight usb cable. It's still a 5 pin USB cable however (Regular USB on one side, small 5 pin connecter on the other side))
Canon Office... | Answered on Aug 30, 2020
Canon iPF610 InkJet Plotter Printer Logo
9 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon ipf610 hardware error 03800500
  • Office Equipment & Supplies
