20 Most Recent
ASUS G73SW3DE Republic of Gamers 173Inch 3D Gaming Laptop Questions & Answers
Laptop shut down and wont power up
Unplug, remove battery, check for dust in fans and vents, plug in, try to reboot. If it powers up, open Control Panel, Power Options Power , set to High Performance, open Advanced Power settings, set Sleep and Hibernate to Never, Adjust other Advanced settings to your preference. Has it been pulled by the cord? If you have a multimeter check for DC volts at the AC jack plug, that plugs into the laptop. Is the Transformer (brick on the cord) getting warm when plug in? Does the battery charge LED light? Try another cord with the EXACT same power specs.
ASUS G73jh Start-up Power BUTTON Problem
Hello ,I can take remote access of your system and fix issue for you, one time charges USD 30; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
Msata asus g55vw
if you're asking "can it be done" then the answer is yes but it is not easy. if your asus is still under warranty, adding an msata drive or RAM on the otherside of the motherboard will void your warranty, if that is not your question, please elaborate.
Asus Laptop G156 - Dual-Core 15.6
The G-series are the gamer (RoG) series by Asus. It might be a G53, atleast that one has a 15" lcd. Of course there are previous RoG's with 15" too, and they tend to hold their cost-level.
Asus G2S back light screen faulty
your bios needs to be reset all you do is open laptop and remove small battery its like the same size as a penny and take out for 30sec and then put back in if that dont work you need to get your gpu checked it might be overheating an reballing work might be needed or feflow i hope that helps
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
