if there is a small hole on the panel of your cd / dvd drive push a straightened paper clip inside until you feel it press down this will open up the driveif this fails to open it upif your computer came with a motherboard disk the drivers could be on itclick start control panel administrive tools computer management device manager scroll down cd / dvd drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driveror select properties general troubleshoot, select driver click to reinstall drivers click update driver you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizardhope this helps
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install driversthe driver might be on the disc supplied by your ISP internet service provideror the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure itsenabled hope this helps
This isn't a pc, you can't connect it to a server, only to a router with direct access to the internet. And it must be configured properly - as explained in the user manual. Also make sure that the IP settings from the player match the ones from the router.
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
Please record the amount of time that it takes until your device goes into sleep mode and set a timer for 5 minutes less than that time everytime you begin to use the lg device. At the points the timer/alarm goes off, you can simply lower/increase the volume and the lg's internal sleep timer should be reset.
Thank you.
Please try using an alternative connection to the hdmit and test the monitor buttons again. And using analog mode prior to testing the monitor buttons again sounds like a good test as well.
Thank you.
