20 Most Recent Kyocera FS1370DN Laser Printer Questions & Answers
First you have to upgrade the firmware to the latest. If the error code appears again, then you have to replace the main pwb assy (controller).
Kyocera FS1370DN... | Answered on May 31, 2018
thanks but where do i find the fuser of the kyocera in the printer
Kyocera FS1370DN... | Answered on Dec 15, 2014
This is refer to communication error between the printer and the extra drawer. If you power on the printer without an extra pf unit, does the printer power on?
Kyocera FS1370DN... | Answered on Oct 11, 2014
Main PWB is defective. So it has to be replaced.
Press Menu button, then press the up arrow until you find the Adjust/Maintenance. Press the right arrow and search with the up arrow the Service choice. Then press the right button and search with the up or down arrow for Maintenance. Press the OK twice and the Install MK will disappear.
Kyocera FS1370DN... | Answered on Oct 08, 2014
First try to change a cable, max 3m USB, max 100m ethernet.
Also try to update the printer's firmware.
Kyocera FS1370DN... | Answered on Sep 28, 2014
Control PWB - Operation panel PWB communication error. You might have a bad operation panel or the connector to the panel may be loose.
communication error
Kyocera FS1370DN... | Answered on Sep 05, 2014
Empty the waste toner from the back side of the drum unit. Then remove and reinsert the waste toner sensor connector from the controller assy (main pwb).
Kyocera FS1370DN... | Answered on Jun 11, 2014
1. Remove the printer in System Preferences ' Print & Scan
2. Added the printer, again
3. Under the IP tab at the top of Add Printer, I chose the LPD option to the right of Protocol, instead of IPP
Kyocera FS1370DN... | Answered on Dec 26, 2013
Kyocera FS1370DN Laser Printer Logo
46 questions posted
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
kyocera fs1370 reset
  • Office Equipment & Supplies
