20 Most Recent Midland LXT326 Two Way Radio Questions & Answers
Check your charger.
Check your radio programming.
Post back with further questions.
Best regards.
Midland LXT326... | Answered on Feb 17, 2016
See other entry...
Peter
Midland LXT326... | Answered on Mar 06, 2013
You should be able to put in the make/model number followed by headset and that will get you to the ones you need.
Midland LXT326... | Answered on Jan 24, 2013
I think you meant 70-0351c?
I believe this is a 60 watt transceiver. So if you remember ohms law P=IxE or power equals amps times volts so 5 amps times 12 volts equals 60 watts. Use a 5 amp fuse.
Midland Radio... | Answered on Aug 29, 2019
Contact Midland directly to inquire.
Midland Radio... | Answered on Jul 29, 2019
If its a real old radio Midland may not have it---Google that model number with "manual" to see what is available.
Midland Radio... | Answered on May 30, 2019
NOT SOMETHING THAT YOU PROGRAM . YOU JUST TURN IT ON THEN SELECT THE CHANNEL YOU WANT TO USE .
Midland Radio... | Answered on Apr 12, 2019
go to radio shack or best buy you need a step up transformer .or you can buy a travel kit and you dont need a lot of watts transformer to do this dont let them rip you off on a high watt one.
Midland Radio... | Answered on Mar 01, 2019
Yes. They call it silent operation.
To set SILENT OPERATION, press the MENU button until the display shows a "bP" icon. Select "on" or "oF" by pressing the s\t buttons and push the PTT key or MENU button.
Midland Radio... | Answered on Nov 02, 2018
Not on FRS. FRS has only one power level and it's set to low.
GMRS ERP output on the 1050 is approximately 0.4w low; 1.5w mid; and 3.07w High according to operator blogs.
Midland Radio... | Answered on Sep 30, 2018
Midland LXT326 Two Way Radio Logo
6 questions posted
Top Midland Radio Communications Experts
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Midland Radio Communications
Most Popular Question
new batteries worked great two days
  • Radio Communications
