20 Most Recent
WYSE WY-150 AMBER 80 (90098307) Network Terminal Questions & Answers
I work on Wyse terminals,
Hi and welcome to FixYa,
A few ideas you may want to consider/try:
- modify/replace (with a slightly higher value) the dropping resistor supplying the horizontal drive transistor through the HD transformer;
- substitute the HD transistor with a higher rating/capacity;
- select a substitute HD transistor in TO-126 packing that would allow a small heatsink to be attached.
Unfortunately, no available schematics for the 150 on my end, but on others that use a 2SC1213 as the HD transistor, replaced the 39 ohms dropping resistor with 47 ohms
Good luck and thank you for asking FixYa.
How do you reset factory
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
