20 Most Recent Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive Questions & Answers
5answers
My kingston 8gb flash drive shows 0bytes
Dont worry, you can usb flash drive recovery software like asoftech data recovery to get back your files. You may refer to this step by step guidehow to recover files from USB driveYou may check out this video tutorial also
2/21/2013 10:12:57 AM • Kingston Digital... • Answered on Feb 21, 2013
USB flash
What format is the drive In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space. The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files. Purchase a large capacity USB external hard disk drive from a reputable vendor. Make sure that the hard disk drive is at least 100 GB. Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive. Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E." Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete. Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard. Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window. Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes. File transfer software http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces. Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
1/31/2013 5:09:52 AM • Kingston Digital... • Answered on Jan 31, 2013
It was taken out of laptop incorrectly
which operating system ?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if you can now see your Kingston data travellerclick start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved click start control panel scroll to folder options view place a tick in show hidden files folders and drivesthis may vary depending on your operating system if you need more help with this post a reply
hope this helps
9/26/2012 11:59:23 PM • Kingston Digital... • Answered on Sep 26, 2012
Loaded my 8G Kingston USB. Next day, properties says zero files, zero free space
Which ever it sounds like it has been exposed to a magnetic field, like a stereo speaker.Gillight
6/24/2012 6:41:21 AM • Kingston Digital... • Answered on Jun 24, 2012
I have DT101Y/8G.I forgot my password, and with hint I couldn't understavd what is my password.If I format it, I won't have privacy zone.I cheched kingston site but There are no downloads or d
With the flash drive you may not have a choice but to reformat. The only suggestion is try www.ebay.com Type: flash drive password
4/13/2012 12:05:37 AM • Kingston Digital... • Answered on Apr 13, 2012
Usb device is malfunctioned
it mean ur burned the chip .. it is useless now
1/9/2012 11:33:55 AM • Kingston Digital... • Answered on Jan 09, 2012
Memory is not find
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a repy hope this helps you
9/29/2011 1:53:37 PM • Kingston Digital... • Answered on Sep 29, 2011
How to use a usb drive have plugged into lap top
Click "my computer" there you will see the flash drive, you can open it and make a folder and you can drag a file and store it their when you are done and want to remove the flash drive do not just pull it out, your flash may be damage you should eject it properly. good day and best regards.
8/23/2011 12:29:36 PM • Kingston Digital... • Answered on Aug 23, 2011
How do I use 8GB to my computer to load my data
an example of hoe to copy photo's/data to a usb drive
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
hope this helps
8/20/2011 10:10:54 PM • Kingston Digital... • Answered on Aug 20, 2011
2answers
My USB is write protect
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also If you are running a Windows XP OS then you might be able to: - click start right click on my computer select open - Right click the icon of your Flash Drive (It should be F:/ or something) - Click Properties in the menu that comes up - Click the Sharing tab - Click permissions - And finally, click Allow next to Full Control. hope this helps you
7/13/2011 6:53:38 AM • Kingston Digital... • Answered on Jul 13, 2011
Kingston datatraveler 8G shows write
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
6/1/2011 9:49:40 AM • Kingston Digital... • Answered on Jun 01, 2011
0answers
0answers
0answers
What year was house built on 31 Nolan crescent Kingston tasmania
Approximately 1984
5/12/2017 9:47:32 AM • Kingston... • Answered on May 12, 2017
0answers
0answers
Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive Logo
18 questions posted
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
  • Computers & Internet
