20 Most Recent Canon REBEL T2i EOS 550D Digital Camera with 50mm lens Questions & Answers
Canon rebel t2i has water damage
This is bad. Contact Canon customer support.
9/25/2018 7:06:10 PM • Canon REBEL T2i... • Answered on Sep 25, 2018
2answers
The manual setting was working fine and now only produces white exposures.
F stop motor/mechanism is stuck on wide open - consequently you get terrible over exposures. And if it does not work on manual I doubt if it will work on auto setting. Repair will be very expensive.
4/8/2016 11:35:06 PM • Canon REBEL T2i... • Answered on Apr 08, 2016
How to convert my raw images
Photoshop, GIMP, Rawtherapee, Darktable, Lightroom, etc... You can even do it in batch with linux. But I recomend to set the camera to jpeg+raw and let the camera do the conversion for you. Then if you need an special retouch of a photo, use any of the above applications.
2/24/2015 7:35:35 AM • Canon REBEL T2i... • Answered on Feb 24, 2015
Canon 55o d will not turn on
Try another battery first. Many of the cheap Chinese batteries won't hold a charge.Otherwise it sounds like you might have water damage to the circuit board that his shorting out the battery
3/21/2013 12:43:52 AM • Canon REBEL T2i... • Answered on Mar 21, 2013
Canon EOS 550D won't turn on
If you have Magic Lantern installed on your camera and it won't turn on, all I had to was re-format the SD card. Works perfectly now. You just need to get rid of ML.
12/13/2012 6:49:04 PM • Canon REBEL T2i... • Answered on Dec 13, 2012
I have heard that Digital cameras have a limited
Any mechanical device will eventually wear out, and a DSLR has many moving parts. The shutter and the mirror mechanism are prime examples, but in addition there are buttons and dials.
There's nothing in the camera keeping track of the date or number of pictures and then stopping operation when some limit is reached. In normal operation, the camera should be good for years and/or tens (or hundreds) of thousands of pictures.
7/12/2011 5:21:38 PM • Canon REBEL T2i... • Answered on Jul 12, 2011
My canon rebel t4i touch screen shows the photos,
If you ligthly press the shutter button then the screen with the settings must appear. The same with the "Q" button.
9/25/2018 7:03:44 PM • Canon Rebel... • Answered on Sep 25, 2018
CANON REBEL XS
It can happen if you are in the Auto-No Flash mode. Or if the flash release button is stuck. Contact customer service, and have a pro take a look at your camera.
9/25/2018 6:56:24 PM • Canon Rebel... • Answered on Sep 25, 2018
Hey so I took my camera to the beach one day and despite the great lengths I went through to keep my camera away from the water, a wave got to it and it got wet. I assumed it only got wet on the outsi
It can be fixed - what you have to decide is if the repair cost is cost effective. Because if you can get a new camera for about the same price as a repair, then .....................
3/16/2017 2:00:58 AM • Canon Rebel... • Answered on Mar 16, 2017
2answers
Vivitar 3200 flash with Canon EOS Rebel T3
it will work with your rebel t3 just set the flash on manual mode and adjust the desired flash power needed .
1/3/2015 5:46:38 AM • Canon Rebel... • Answered on Jan 03, 2015
Black screen on canon powershot a1200 can see the symbols and takes black pictures
Hello Now please can u tell me hat is the solution of that problem Thanks
11/23/2014 10:27:49 PM • Canon Rebel... • Answered on Nov 23, 2014
Trying to download pics from computer and get error 31, but then camera automatically disconnects itself
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/15/2014 8:23:09 PM • Canon Rebel... • Answered on Nov 15, 2014
Where can i get a user manual for canon rebel
If you mean the original Digital Rebel you may download the manual and more from http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_digital_rebel#BrochuresAndManuals If you mean some other Rebel model, which one?
8/24/2014 7:41:03 PM • Canon Rebel... • Answered on Aug 24, 2014
Auto focus light is blinking red on my canon camera
Try a different lens. Either the lens is bad or the connections are dirty.
8/22/2014 1:03:04 PM • Canon Rebel... • Answered on Aug 22, 2014
Why would brand new battery only charge half way?the old one ewas doing this and only lasted minuets so bought a new batery
I can only guess that you are not using a charger that's designed for the battery. I have experienced the same problem.
7/30/2014 6:56:57 PM • Canon Rebel... • Answered on Jul 30, 2014
Liquid soap inside the screen
The soap is probably between the back light and the LCD itself, on one of the plastic Fresnel screens. You may be able to clean it off with Windex on a Q-tip. Remove back cover (can't give directions without knowing which model)
5/23/2014 4:04:40 PM • Canon Rebel... • Answered on May 23, 2014
Focus lights are Dim on My 1100d
Remove black side cover (two screws) and rear cover and check the rear circuit board for a missing screw in the lower right corner. Find screw and replace. If it did not short out the circuit you should see the function return. Other, send to Canon for circuit replacement
5/14/2014 1:16:13 AM • Canon Rebel... • Answered on May 14, 2014
I have a canon rebel xsi and sigma 100-300 zoom lens. I get an error Err01 when shooting. It says communications error and clean contacts which I have done. Is there an incompatibility issue?
I don't think there will be an incompatibility issue. If your other lens(es) work well, your camera must be ok. But not only dirty contacts can cause trouble. If a very small dent is in one of the contacts of the camera, or one of the contacts from the lens is a bit to far pressed in, you also have a bad or not existing contact with the same error. In the lens also something can be wrong. I strongly suggest to try the lens on an other camera and see what that brings.If the error goos with the lens to the other camera, you know where to look. But I think only professionals can repair you lens if it is defect.
1/7/2014 8:24:09 PM • Canon Rebel... • Answered on Jan 07, 2014
Canon REBEL T2i EOS 550D Digital Camera with 50mm lens Logo
Popular Tags
6 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Rebel Canon
  • Rebel Canon
Most Popular Question
canon rebel t2i water damage
  • Cameras
