20 Most Recent Xerox WorkCentre 470CX InkJet Printer Questions & Answers
Yes surely, only the power supply part of the printer is having problem, get it serviced by the technician.
Xerox WorkCentre... | Answered on Sep 05, 2010
You can downlad the vista driver from the xerox website and try but 470cx is not supported yet with windows 7 http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=470cx&ripId=&Xtype=download
Xerox WorkCentre... | Answered on Nov 21, 2009
You can get a parallel print server and configure that.These may be hard to find though.
Xerox WorkCentre... | Answered on Jul 22, 2009
You will need a parrallel cable that supports IEEE standard 1284 and is not longer than 12 feet.
You can consult the online user guide available by clicking here and go to page 1-8. If your laptop does not have a parrallel port you will need to purchase a usb to parrallel adapter cable like the one shown here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Xerox WorkCentre... | Answered on Apr 20, 2009
Usually when part of the Carriage is broken, it involves taking the Carriage Assembly apart which also deals with the head assembly, Timing , etc. I would call your local Xerox dealer or printer repair depot. Get an estimate then make a decision whether it's economical to have it repaired.
I could not find a service manual for your unit. I did find this on Xerox's site:
If the Ink Cartridges do not snap in straight or seem loose, the Carriage may be broken and your WorkCentre will require service. Click "Email for Support" in the Please Help section at the bottom of this page to contact Team Xerox for service
1-800-ASK-XEROX or 1-800-275-9376
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Xerox WorkCentre... | Answered on Nov 21, 2008
Somehow, a group dial # has been set. Here is how to delete it:
NOTE: Group Dial Numbers are entered using the One-Touch keypad on the left hand side of the WorkCentre. To change a Speed Dial that is within a Group Dial, the Group must be deleted first.
  1. Press the [Menu] button.
  2. On the left hand side of the Control Panel press the One-Touch [12] button.
  3. The LCD Display will read 'Select One-Touch for Group [01-20]'.
  4. Press the One-Touch key to be used for the Group Dial.
  5. One of two displays will appear:
    • If the Group Dial number has not been used:
      1. The LCD Display will read 'Group No: ### 1. YES 2. NO'.
      2. Using the Dialing Keypad press [1] to accept or
      3. Press [2] to return to step four.
      4. The LCD Display will read 'Enter One-Touch / Speed Dial> ##'.
      5. Continue with step 6.
    • If the Group Dial number has been used:
      1. The LCD Display will read 'Group ## Used 1: Renew 2: Other'.
      2. Using the Dialing Keypad press [1] to 'Renew'. This will cancel the Speed Dial or Group Dial entry and the Group Dial will be deleted.
      3. Press [2] to keep the current entry and select another Group Dial
      4. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
        Thanks, Joe
Xerox WorkCentre... | Answered on Oct 12, 2008
That error indicates low toner concentration in magenta. Enter diagnostics, select max setup, select toneup/tone down button, select trc control, select the start button. See if you get a result or a failure. If it fails replace the ATC sensor.
Xerox Office... | Answered 15 hours ago
The answer to this question is nothing I can find. Best to contact the Customer Support Center for Xerox the number is supposedly on the machine. Good luck!
Xerox Office... | Answered on Jan 13, 2020
May be a defective toner cartridge - try a another to find out.
https://www.support.xerox.com/en-us/article/en/1849270.html
Xerox Office... | Answered on Jan 12, 2020
try a different toner cartridge. sounds defective cartridge'
Xerox WorkCentre 470CX InkJet Printer Logo
Popular Tags
14 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
xerox workcentre 470cx printer no longer
  • Office Equipment & Supplies
