20 Most Recent Xerox WorkCentre M940 InkJet Printer Questions & Answers
You can download and print the instruction manual in PDF format from Xerox website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Xerox WorkCentre... | Answered on Aug 26, 2010
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Xerox WorkCentre... | Answered on Apr 15, 2010
There are some soft pads in the bottom where the ink cartridges sit.
Try this. Unplug the printer. lay some paper towells under where the print cartridges are inserted and drip some alcohol down into that area. That will soften and unclog the print head. Do that a ferw times to losten up the ink and flush it out. Then allow the printer to sit for a while then run several test pages. Most of the time that will resolve the problem you are having, Those liquid inks dry and get very tacky and will not allow ink to flow properly.
Xerox WorkCentre... | Answered on Feb 15, 2010
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Xerox WorkCentre... | Answered on Feb 05, 2010
no, but you can download it yourself, from this site.
Xerox Driver Page
Xerox WorkCentre... | Answered on Jan 01, 2009
Call, 1-800-828-5881 then follow prompts 4 then 3. They should be able to look that up and order you the proper disks. If not they will direct you to who can.
Xerox WorkCentre... | Answered on Feb 21, 2008
Xerox has some fantastic support information on their site. I can't say enough about how much detail they provide. One of their documents for your printer is, "Solutions for How To Resolve an F952 Error Message." The document can be found at the following location: http://www.support.xerox.com/go/go.asp?ksessID={88EEB946-3A34-4AF9-801B-0756917C085D}&Xlang=en_US&Xcntry=USA&prodID=M940&objID=6581 NOTE: After clicking the link above, you'll need to click the link, "Continue to the Support page" at the bottom of the page. If their information doesn't resolve the issue, please let us know.
Xerox WorkCentre... | Answered on Feb 17, 2008
Check if u have put on cartrigdes correctlly and check for driver
Xerox WorkCentre... | Answered on Oct 18, 2007
Does the printer power on? How do you have it connected to the computer? I.e., does it use a usb cable, parallel cable, or is it connected through the network?
Xerox WorkCentre... | Answered on Sep 15, 2007
Hi.
  • Code: 045-310
  • Description:Image Ready Error Unable to send the Image-valid signal cannot within the specified time. NOTE: When the attempt to expand the image has failed, [016-776 Marker Code Detection Fail] occurs after the recover operation.
  • Remedy:1. Check the USB Cable (Local) for poor connection. 2. If no problem is found, replace the ESS/MCU PWB. (PL 18.1).
Good luck.
Xerox Office... | Answered 15 hours ago
Xerox 5775 the folt is machine speed invalid error
Xerox Office... | Answered on Feb 27, 2020
try a different toner cartridge. sounds defective cartridge'
Xerox Office... | Answered on Feb 17, 2020
I earned $5000 ultimate month by using operating online only for 5 to 8 hours on my computer and this was so smooth that i personally couldn't accept as true with before working on this website. if you too need to earn this sort of huge cash then come and be part of us. do this internet-website online ...........
Here..... http://www.Neway9.com
Xerox Office... | Answered on Feb 13, 2020
Thank you for reading the At Your Service blog. Please make sure the machine is plugged into a dedicated outlet with no surge protector or power strip. If the problem continues in a dedicated outlet then turn the machine off and unplug the network cable. Turn the machine back on with the network cable still disconnected. If the machine comes on properly then there is an issue with the network. If it still loops consider contacting consider contacting your local support centre for additional assistance.
Xerox Office... | Answered on Feb 11, 2020
Xerox WorkCentre M940 InkJet Printer Logo
Popular Tags
12 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
working fine ran out ink bought new
  • Office Equipment & Supplies
