20 Most Recent
Philips Norelco Hq200 Jet Clean Solution 2 Pack Questions & Answers
How do i clean my with my philips hq2000. instructions are in a different langue
Set the Jet Clean System base on a flat surface and pull the cleaning reservoir out of the base.
Unscrew the fill cap on the reservoir, pour Jet Clean Solution into the reservoir and replace the reservoir in the base.
Plug the power cord of the cleaning base into and electrical outlet.
Remove the protective cover on the razor head and place it to the side. The protective cover must be removed or the cleaning system will not work.
5
Slide the razor head into the base, push back on the razor handle and press the locking lever down to keep it in place. The indicator light on the cleaning base will blink, indicating the razor is inserted properly and charging.
6
Press the "On/Off" button on the side of the cleaning base. The razor will lower into the cleaning solution and begin the cleaning process, which takes approximately one hour. The razor will rise out of the cleaning solution when the cleaning process is complete.
7
Lift up on the locking lever, remove the razor from the cleaning base and rinse the razor heads under warm water to remove any remaining cleaning solution. The razor is now clean and ready for use.
If you just have the solution and not the Jet Clean System, then I would presume you could soak just the heads in the solution to clean them and then rinse it off.
Blade for Philips HR1115
https://www.google.com/search?q=Blade+for+Philips+HR1115&oq=Blade+for+Philips+HR1115&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Philips sonicare toothbrush turns itself on
Its haunted. you need a priest to bless it with holy water.
Or the button is stuck with toothpaste. Mine did that and the battery ended up failing a few weeks later. New ones are lot cheaper than when I bought my first sonicare.
My philips Sonicare airfloss won't shoot fluid when I press the button.
If the spray of your Philips Sonicare AirFloss becomes less powerful or stops spraying all together, you can often fix is yourself. Just follow these steps.
Clean the vent
There is a small vent in the reservoir door opening to let air in as water is drawn out of the reservoir for every burst. If the vent is blocked it will reduce and eventually stop the water flow.
If this vent is blocked, you must clean it using the following steps:
- Use a piece of paper towel or a cotton swab.
- Moisten (not soak) the paper towel or cotton swab in water.
- Clean the vent by wiping along the inside edge of the reservoir opening especially at the top of the opening closest to the nozzle end of the device.
- Also wipe along the outside of the inside edge of the reservoir door along the top of the door closest to the nozzle end of the device.
- Rinse very well with cold tap water and ensure no debris is left, from the paper towel or cotton swab, in the reservoir or along the edge of the opening or the inside of the door.
- Be careful not to allow debris into the reservoir fill opening.
