20 Most Recent Roland Boss BR 900cd Digital Recorder BR 900 Questions & Answers
I assume you have tried formatting the card in the BR900... sometimes formatting in the PC's doesn't work. read at this web page:
http://launch.groups.yahoo.com/group/BossBr/message/1905
Roland Boss BR... | Answered on Aug 30, 2016
contact the manufacturer perhaps they know
Roland Boss BR... | Answered on Nov 27, 2015
There is a complete section about this in the user manual, starting on page 161.
http://roland.com/support/article/?q=downloads&p=BR-900CD
Roland Boss BR... | Answered on Sep 04, 2015
Try non conductive electronics spray contact cleaner,
I have used this for many similar repairs,
hope that helps? RadioShack TV Tuner Cleaner Cleaners RadioShack com
You'd be best off contacting Roland support. Here is a link-
Roland Backstage Login
Use the USB cable and follow the instructions in the user manual. You can download the manual and updated software from here:
Roland Boss BR... | Answered on May 13, 2015
You can upload it to an online service such as: http://audio.online-convert.com/convert-to-wav ; or use a software package to do it locally: http://pcsupport.about.com/od/fileextensions/tp/free-audio-converter.htm
I hate to say it, Sandra, but that problem usually doesn't involve an easy/cheap fix. I run a 1200 here, so I know from whence you speak. If this is an "under warranty unit", I'd box it up and swap it out.
BUT, if not, and you're any good at dis-assembly/re-assembly or know someone who is, I HAVE fixed problems like this with the "pressure" method. It worked on a Chevy digital dash that was blanking out on me and a couple music keyboards.
Power it down and unplug the power cord, dis-assemble it to the point you can see the board that feeds the display. Very carefully plug the power cord back in and power it up. While avoiding touching any of the boards or connections with your bare hands/fingers, use a pencil eraser and lightly apply pressure to different spots on that board until (maybe) the display lights - indicating a loose connection; probably a bad solder joint in that area. Trying to repair it would probably fry it, unless you're an ace solderer.
Now, the trick is to remember that spot, use a piece of non-conductive material, like a small wad of electrical tape big enough that it would apply a similar constant pressure to it at that point once it's re-assembled. I know - sounds bizarre, but I've made it work where soldering was impossible without a professional teardown.
Good luck,
jim
Roland Boss BR... | Answered on Mar 12, 2014
Hello, that seems to be a bad contact on the enter button, the solution is to take a part the key and clean it, otherwise you need to replace the under key switch.
Thanks
Roland Boss BR... | Answered on Nov 22, 2013
If this is a traditional keyboard (not laptop) or extremely fancy keyboard.
Try unplugging the keyboard. Then.
  1. Take a butter knife and slide it into the crevice next to the "enter key".
  2. Apply a small amount of pressure to pry the key upward.
  3. With little effort the key should pop off or slide off.
  4. Check the spot the key was for dirt, dust, food, etc. Clean it if you must. Make sure the actual key does not have anything stuck to the bottom of it.
  5. Push the key back onto it's place on the keyboard.
  6. Plug back in and see if that worked.
If this did not work, you may need to replace the keyboard OR you may want to make sure no viruses are playing an aweful trick on you.
Roland Boss BR 900cd Digital Recorder BR 900 Logo
32 questions posted
Top Roland Music Experts
Marvin
Marvin
Vernon Taylor
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
fix play button br 900cd not engage when
  • Music
