20 Most Recent
Macally BT-SYNC Bluetooth (BTSYNC) Wireless Adapter Questions & Answers
My bluetooth usb wont work on my laptop .I usein
Initially check whether the drivers for the blue tooth is installed or not .
This can be seen from the device manager if there is no drivers installed for it install the drives needed for it by using the cd provided with the blue tooth.
.After installing the drivers when u plug the dongle you have got led blinking inside the device if the led is available .
if the above steps give you positive result sure your bluetooth will work. if not there may be some problem in the device
My macally keyboard doesn't stay on even when fully charged
There are a few potential reasons why your Macally keyboard is not staying on even when fully charged:
- Battery issues: The battery in the keyboard may be faulty or malfunctioning. It's possible that the battery is not holding a charge or is not working properly.
- Power management settings: Check your keyboard's power management settings and make sure that it is set to stay on when fully charged. Some keyboards have a sleep mode that turns off the keyboard when not in use to conserve power.
- Connectivity issues: Make sure that the keyboard is properly connected to your computer. Also check if the keyboard works with other devices.
- Firmware update: Make sure you have the latest firmware update for your keyboard. Sometimes an update can fix any bugs that cause the keyboard to turn off when it's fully charged.
- Damaged charging port: The charging port of the keyboard may be damaged and not able to charge the battery.
It's recommended to contact the manufacturer's customer support team, they will be able to assist you in diagnosing the problem and provide a solution. If the keyboard is still under warranty, you may be able to get it repaired or replaced for free.
1/16/2023 11:55:24 PM •
Macally...
Answered
on Jan 16, 2023
Connecting a USB keyboard to my iMac
Adding the keyboard is one thing but without the correct driver, your pc will not be able to recognise it or make it usable. Check in your device list to see if it shows up and whether it is functioning. If not, you need to download the correct driver from the keyboard manufacturer.
9/19/2017 3:57:49 AM •
Macally...
Answered
on Sep 19, 2017
