20 Most Recent
A D S (PTV-390-W3) (PTV390W3) Video Capture Questions & Answers
Not Capturing Sound
If you can hear the sound while capturing, it's probably not a hardware problem. First - the obvious - go to your Volume icon in your systray (lower right hand corner). Right click on the icon. Then click on adjust audio properties. That will open a window that will show playback and recording volumes. Make sure they are both at least half way. If it is, make sure that the software and drivers you're using are all updates. If they are, you may be using a corrupt codec or for some reason it is not used correctly. Try completely uninstalling the application, manually deleting the registry entries and configuration files, and reinstalling the application from scratch. Good luck.
4/4/2006 10:56:40 AM •
A D S...
Answered
on Apr 04, 2006
The vcr input do not work
it could be a problem with the connector itself, try connecting many devices to it and if it doesn't work, check that the connector isn't loose.If it is,then is probably not going to work unless you get inside and fix the connections.
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
