20 Most Recent
Macsense XRouter Pro MIH-130A (MIH-130A/6) Questions & Answers
I dont know crouter configuration
Dear sir,
Here's How:
- Choose a convenient location to begin installing your router such as an open floor space or table. This does not need to be the permanent location of the device. Particularly for wireless routers, you may find it necessary to re-position the unit after installing it as the cables / signals may not reach all areas needed. At the beginning, its better to choose a location where it's easiest to work with the router and worry about final placement later.
- Plug in the router's electrical power source, then turn on the router by pushing the power button.
- (Optional) Connect your Internet modem to the router. Most network modems connect via an Ethernet cable but USB connections are becoming increasingly common. The cable plugs into the router jack named "WAN" or "uplink" or "Internet." After connecting the cable, be sure to power cycle (turn off and turn back on) the modem to ensure the router recognizes it.
- Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. Using a cable during router installation ensures the maximum reliability of the equipment. Once a wireless router installation is complete, the computer can be changed over to a wireless connection if desired.
- Open the router's administration tool. From the computer connected to the router, first open your Web browser. Then enter the router's address for network administration in the Web address field and hit return to reach the router's home page.
Many routers are reached by either the Web address "http://192.168.1.1" or "http://192.168.0.1" Consult your router's documentation to determine the exact address for your model. Note that you do not need a working Internet connection for this step.
- Log in to the router. The router's home page will ask you for a username and password. Both are provided in the router's documentation. You should change the router's password for security reasons, but do this after the installation is complete to avoid unnecessary complications during the basic setup.
- If you want your router to connect to the Internet, you must enter Internet connection information into that section of the router's configuration (exact location varies). If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider (you would need to have requested it), the static IP fields (including network mask and gateway) given to you by the provider must also must be set in the router.
- If you were using a primary computer or an older network router to connect to the Internet, your provider may require you to update the MAC address of the router with the MAC address of the device you were using previously. Read How to Change a MAC Address for a detailed description of this process.
- If this is a wireless router, change the network name (often called SSID). While the router comes to you with a network name set at the factory, you will never want to use this name on your network. Read How to Change the Router SSID for detailed instructions.
- Verify the network connection is working between your one computer and the router. To do this, you must confirmed that the computer has received IP address information from the router. See How to Find IP Addresses for a description of this process.
- (If applicable) Verify your one computer can connect to the Internet properly. Open your Web browser and visit a few Internet sites such as http://compnetworking.about.com/.
- Connect additional computers to the router as needed. If connecting wirelessly, ensure the network name (SSID) of each is computer matches that of the router.
- Finally, configure additional network security features as desired to guard your systems against Internet attackers. These WiFi Home Network Security Tips offer a good checklist to follow.
Tips:
- When connecting devices with network cables, be sure each end of the cable connects tightly. Loose cables are one of the most common sources of network setup problems.
What You Need:
- A network router (wireless or wired)
- Network adapters installed on all devices to be connected to the router
- A working Internet modem (optional)
- A Web browser installed at least one computer in the network
regards
murali
Port forwarding ? XRouter MIH-1340A
I love port forwarding things..
First, you need to find out what your link to the admin panel is.
To find that go to start>run>type cmd and hit enter.
Now in that black type "ipconfig" and press enter(w/o quotes)
Look for a "Default Gateway" mine is 192.168.1.1 look for something like that.
Now go into your browser and type that address, now you need to login to the router panel.
Now if you want me to look up the rest I need to know who made your router, and if you don't mind confirming the model number as its above, but I want you to double check please.
Once you do what above and its asking for a user and pass, you need your login. Usally by default mine was admin-user/admin-pass your may be different, Look in your manual that came with the router or call the person that made it they can tell you.
Now when you get inside the panel you'll need to look for an area that says port forwarding.
I have no idea where it is, thus I do not know the exact model, and make of your router.
It will ask for UCP,etc just put both in that option.
Then the only part you should have trouble on is the IP.
It should say like 192.168.1. and a blank that you fill in.
In those last 3 you would put 103,104,etc this is how you find out.
Go to that black screen that was up above, and type ipconfig/all and look for your Physical Address, or IP mine looks like 192.168.1.102 in that blank for me I would put 102.
One that IP Camera you need to find outs its IP, look in the manual..
I hope this helps educate you some what.
-Cam
Had thunderstorm here in Houston.
Welcome to Fixya. I would like to verify the red light that your referring to the MacSense is it the power button? If the red light was not turning on and the modem has been replaced by a new one the settings on the router is not changed most likely that it was also damage by the storm. If you were asking what kind of router is a suitable replacement any router will do it will just depends on what is the purpose of that router. All routers that has been released was compatible with mac and pc.You can have a Linksys, Netgear, Cisco or any router that is available in the market.
If you have any questions please let me know. Thanks
7/25/2011 7:18:27 PM •
Macsense...
Answered
on Jul 25, 2011
I use an iMac 21.5"
delete the epson scan app and reinstall it with the latest drivers from epson.
5/15/2011 8:09:05 AM •
Macsense...
Answered
on May 15, 2011
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
