20 Most Recent Marshall Amplification Marshall MG15FX Guitar Combo Amplifier - 8 Inch, 15 Watts Questions & Answers
you may have a loose connection
Marshall... | Answered on Jan 06, 2013
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Marshall... | Answered on Aug 07, 2012
Mixer uses balanced outputs, this unit does not... Also ground loops can be a problem. Make sure this and the mixer are BOTH powered from the same receptacle. The next problem is that the level of the mixer is MUCH too high for an amp designed to recieve guitar signals if you are sending a mixer into this. It is NOT clear how you are connecting this to a mixer... IF you happen to be trying to send signals from this to a mixer, either use a mic OR use a Direct Input box. You should tell us exactly how you are connecting this to the mixer since there are MANY ways, and most do not make sense.
Marshall... | Answered on Aug 08, 2011
check to see if your fuses are blown should be an easy fix
Marshall... | Answered on May 05, 2011
https://www.manualslib.com/manual/99237/Marshall-Amplification-Mg15msii.html
Marshall... | Answered on Jan 17, 2019
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
Marshall... | Answered on Jan 08, 2018
Most likely cause for this is an intermittent potentiometer. Check to see if any of them are mechanically loose as this is a sign that they have been damaged and could have cracked the wiper surface inside the pot causing this problem. Alternatively, any switch that controls any gain setting could also be intermittent or dirty. Gain of the amplifier should be stable, but is controlled by the feedback and signal injection at the pots so that is where to look first. Good luck, as intermittent problems are tricky, but sometimes better than no function at all which can be more costly.
Marshall... | Answered on Nov 21, 2017
Hi. Doesn't look like it as the speaker is a 4 ohm one and the head needs at least 8 ohm as far as I can see.
Marshall... | Answered on Aug 08, 2016
What type of Marshall, please?
First of all, control the fuse and let me know.
Marshall... | Answered on Dec 26, 2015
Does anything happen while you turn the knobs on the amp?
I had a similar problem with a yamaha amp. It turned out a couple of knobs went bad. Soldered new pots and it works fine for me now.
Marshall... | Answered on Mar 29, 2015
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp. Your only option would be to rewire your cabs internally to 16 ohms each by connecting the speakers in parallel, but that would cut your amp's power in half.
Marshall... | Answered on Jan 25, 2015
Marshall Amplification Marshall MG15FX Guitar Combo Amplifier - 8 Inch, 15 Watts Logo
Popular Tags
6 questions posted
Top Marshall Amplification Music Experts
matt martin
matt martin
rhodesworks
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
View Most Popular
  • Marshall Amplification Music
Most Popular Question
gain knob doesn 39 t work
  • Music
