20 Most Recent Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV Questions & Answers
2answers
I have a blicking red light and no picture ?
My Panasonic is showing 22 blinking lights
5/31/2022 2:44:42 PM • Panasonic VIERA... • Answered on May 31, 2022
0answers
Problems
Be the first to answer 4/5/2017 11:24:02 AM • Panasonic VIERA... • Posted on Apr 05, 2017Be the first to answer
TH-42PX60U that has no power and no LED light coming on. Breaker is good and I have replaced the power supply board. Is there another board in the set that would prevent the power from coming on?
Please forgive me if this sounds offensive to youor intelligence, but let's eliminate the obvious , (and free) things first ! I had a similar scare with my used LG HDTV. I had it plugged in to a "Surge Protected" power bar that had 4 of the 10 plugs "Surge Protected". I don't know why, but the TV was plugged into a "Surge Protected" plug, and ZIP!! No power ! Why did I buy a used HDTV, how could I be so thoughtless !. But then, as I noticed my lamp plugged into a non-Surge protected plug, was working, so I plugged the HDTV into a regular plug & "TA DAAA !" Check also to see if the powre plug, often is removable, just maybe look up in your manual "FIRST" and see if you can find if the power cord is removable, if so, the cat hitting it by accident, once, or repeatedly, as with a friend, can slighly remove it. See if this simple thing will take care of it. Sometimes we move things around, and enough stress on the power cord can partially remove it, or there is a permanent "bend damage". Contact the manufacturer to see if you can replace it with the removable power cord of some other appliance, an old "Boom BOX", or how much is a new cord (a lot less than a trip to the repair shop. Did the kids play with the remote and accidentally set the timer, and it went off as it was told to do so ? If your "Plasma HD TV" blew something, feep in mind how hot these things get, try to make sure they have as much space as possible to keep cool, and extend the life of your "loved one", the HDTV that is ! Never be to quick to be upset, and you'll be surprised how simple things can fix it, or all the great people on "FIX YA" will help out. "DON"T BE SHY !!"
4/29/2016 10:54:38 PM • Panasonic VIERA... • Answered on Apr 29, 2016
We just bought this tv second hand and cannot get it started. is there someone that can help
Return and get your money back - seems you have been had. Sure the outlet you plugged it into has power?
3/15/2016 6:46:58 PM • Panasonic VIERA... • Answered on Mar 15, 2016
My TV is producing no sound. I tried everything and still wont work. What is the reason?
Seems your TV's sound providing part has somehow broken if you TV still has warranty call the company and they will repair if not find a local repairer or do it yourself you may be able to order the sound providing part if you remove it and should have a code but only if your expert other ways ring company
2/13/2015 3:47:22 AM • Panasonic VIERA... • Answered on Feb 13, 2015
What could be the cause of a Chaotic image (red and blurry) besides nearby electrical products?
Disconnect all external devices ,if the problem is gone then on of them is the cause,reattach on at a time till the problem returns and that item is the cause,however if the fault persists when all external devices have been removed there is a problem with the tv and further investigation will have to be performed.
9/14/2014 7:47:48 PM • Panasonic VIERA... • Answered on Sep 14, 2014
Blinking red power light on a Panasonic Viera 47 in. plasma
No sure how many blinks you have but here are the blink error codes and the common boards failures for each Blinking Times Contents Check point 1 Panel SOSPanel 3 P+ 3.3V SOS A-Board 4 Power SOS P-Board 5 P+ 5V SOS A-Board 6 Driver SOS1SN-Board 7 Driver SOS2SN-Board 8 Driver SOS3SS-Board 9 Discharge Control A-Board 10 Sub 5V SOSA-Board SN-Board SS-Board P-Board 12 Sound SOS A-Board Speaker 13 Emergency SOS A-Board
5/29/2014 5:44:40 PM • Panasonic VIERA... • Answered on May 29, 2014
Why do I have no sound? ive checked all the settings"
A guess here but do we assume you are using the speakers built into the TV? Also you do not tell what your source is and the type of connection. For instance if you have a VCR with a S-Video connection then you will have a decent picture but no sound as S-Video is strictly for video, you need a left/right RCA cable. If it's HDMI then it handles audio and video but some device you need to configure correctly so the HDMI cable will work.
5/20/2014 2:02:33 AM • Panasonic VIERA... • Answered on May 20, 2014
How easy to repair the power supply
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
5/7/2014 4:30:45 AM • Panasonic VIERA... • Answered on May 07, 2014
2answers
4 inch horizontal gray bars left and right in hd mode, normal channel pic is fine
Please enter the TV's Setup menu and choose the "Other adjust" option. Then choose the "Side bar" option and use the right arrow to change the color of the side bars.
5/5/2014 8:36:56 PM • Panasonic VIERA... • Answered on May 05, 2014
When we turn on our TV, there is a green shadow and green pixals. it lasts for 10-15 minutes and then goes away.
This symptom is the beginning of the end of the TV. Unfortunately, the repair costs, which probably involve the processor, would exceed the price of a new (and better because of features available) TV. Sticking with plasma is logical for price and quality.
11/8/2013 3:04:23 AM • Panasonic VIERA... • Answered on Nov 08, 2013
Green tint in picture
Are the lines completely through the screen or just the upper or lower part of the screen? If through the whole picture, lines in the picture of a plasma can be caused by a defective Main Logic Control board or a bad plasma panel. The panel, if available would be very expensive (cheaper to buy a new TV). If the lines are just on the upper or lower part of the screen then it is the upper or lower scan drive board. Here is a list of the parts for your TV.https://www.tristatemodule.com/t-Search.aspx?q=TH-42PX60U
11/4/2013 9:22:32 PM • Panasonic VIERA... • Answered on Nov 04, 2013
Program tv codes remote
2784,2740,2730,2797 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
10/6/2013 9:57:26 AM • Panasonic VIERA... • Answered on Oct 06, 2013
Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV Logo
73 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
no sound ive checked all settings
  • Televison & Video
