20 Most Recent
Magix MOVIE EDIT PRO 17 HD PLUS Questions & Answers
Serial activation code
Contact the software manufacturer or distributor, they will be able to
assist you. Otherwise the serial number will have been provided on the
paperwork that came with the software when purchased.
I have problem reinstalling magix edit pro 17
Maybe a file in the usual program or configuration directory was locked by another program (e.g. antivirus scans) when you were removing the old edition of Magix Edit Pro; that would leave directories like /Programs/Magix and /Data/Programs/Magix and possibly registry entries (call up RegEdit and delete (or export and then delete) the old items pertaining to Magix or EditPro) around blocking 17 from coming in. Just rename those vestigial directories so they won't be in the install's way. Then retry and report...success?
How do I get a electronic version of the Magix
If you installed from the CD there should be a directory in the installed files called manual
It should be located in C--> Program Files
Otherwise here is a download to the manual for Movie edit pro 16
http://www.archive.org/download/MovieEditPro16Manual/MagixMovieEditPro16Manual.pdf
How do you upload a
You have to import the DVD, after you have click on the start page to create a new movie. In the workspace area, you will see the drives on your computer. Select the DVD drive and it should show the files on the DVD disc. Then import them into the work area. You can then drag the files to the timeline area.
