20 Most Recent Mackie CFX 12 mkII 12 Ch. Compact SR Mixer w/Effects Questions & Answers
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Mackie CFX 12... | Answered on Aug 08, 2018
Assuming if you pan hard left on an input it comes out the left and panning hard right goes nowhere and as you say the tape input feeds through to both sides OK there is a very limited number of places where the problem can be. If you are confident open it up and check all the connectors and cables. If anything has come loose this may find it, otherwise it's a trip to the repair shop. The largest cost will be the taking apart and putting back together as the repair itself should be a simple one and diagnostics easy.
Mackie CFX 12... | Answered on Feb 18, 2014
What makes you think the effects chip is bad? It is LIKELY a fine-pitch DSP that is far beyond what the average tech could do. If you could get one, you would have to take this to a shop specializing in surface mount rework. The chances of this chip being bad is very low. More probable is either pilot error or other circuits, especially those exposed to the external connections.
Mackie CFX 12... | Answered on Aug 29, 2011
Sorry, I have looked at the schematics and the TAPE IN jacks are mixed into the MAIN outs AFTER the insert jacks, so your subs will NOT receive signal via the insert from the TAPE IN jacks.
You could make a small passive mixer merging the TAPE/CD before going to the crossover. This would require some non-standard cabling.... The other option is to run the CD into a regular stereo channel rather than the TAPE IN jacks... then the CD will go through the insert/crossover and to the subs as you desire. The last option is to use the crossover at the MAIN outputs instead of as an insert... which would be the CONVENTIONAL way... use BALANCED cables wherever possible.
Mackie CFX 12... | Answered on Jul 23, 2011
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
Mackie Music | Answered on Sep 27, 2019
Here you go
http://www.mackie.com/products/onyx4bus/pdf/Onyx_4Bus_OM.pdf
This link to the manual is on the Mackie website
Mackie Onyx 32 4
Mackie Music | Answered on Jun 08, 2019
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
Mackie Music | Answered on May 03, 2019
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16
I hope you can solve the problem you have with your Mackie
Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16
Espero que puedas resolver el problema que tengas con tu Mackie
https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
First thing to do is get a can of contact cleaner. Take off the knobs and spray it into the reostats below. Spray into all the switches and even into the sliders. Move everything back and forth - 0 to 10 (to clean them). If we're lucky, that will fix it.
Good Luck
Mackie Music | Answered on Dec 26, 2018
First, unless you are a trained or self-taught audio technician, don't attempt to repair the unit yourself. Let the professionals repair it. You can damage it beyond repair if you don't know what you're doing.
Non-working channels are caused either by bad connections, bad solder joints or a dead IC op-amp.
The causes of weak channels can be more challenging to track down. I'd suspect bad connections, dirty controls or connectors.
Mackie Music | Answered on Nov 06, 2018
Glenn, Does it say 'overvoltage', or simply 'voltage'? For the clearest result brother, contact Mackie - 1-800-898-3211 is their tech line - they're super cool - I just always picture the guys at Mackie sitting around reading comic books and shooting guns into the air. good luck!
Mackie Music | Answered on Sep 29, 2018
Mackie CFX 12 mkII 12 Ch. Compact SR Mixer w/Effects Logo
7 questions posted
Top Mackie Music Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
mackie cfx12 mkii low output across all
  • Music
