20 Most Recent Behringer PMP2000 800 Watt 10 Channel Powered Questions & Answers
Sounds like a few capacitors have just blown, easy fix if your handy with a soldering iorn,
Behringer... | Answered on Dec 23, 2014
Your woofers are probably blown. To check plug a 1/4 inch or speakon into the speaker cabinet with the two bare wires exposed on the opposite end and touch with a 9volt flat battery if the driver doesn't move ir sound it's blown
Well, even a walkman type CD player will have the same CD quality as the most expensive professional DJ player. You can get a little stereo to WYE cable to go to your PA... The disadvantage of the small players are the abilty to que up certain tracks and discs. If you need random track selection and shuffling you will find that most any of the home consumer CD players will have the same audio quality... so pick one that you can do the selections with whatever ease you need. Hint, there are a LOT of CD players at the thrift shops... you can get them for nearly nothing and find a suitable one. Most of those you will need cables with RCA plugs at one or both ends and maybe 1/4 inch plugs at the other depending on whether you want to go into certain channels of the PA.
Behringer... | Answered on Sep 17, 2011
Common causes of this are improper level setup. You MAY be overdriving the inputs. Use the pad buttons to limit the input for higher output devices. Saturating the input(s) will cause bad distortion. Observe if any of the clip indicators are coming on. If they do, then use the pad buttons. If they still come on due to very high output device, you MAY have to use an external attenuator. Every mixer has different characteristics and some can accept a wider inout range than others.
Behringer... | Answered on Jul 05, 2011
Depending on how its built and if your good with circuits i couldnt see why not. If its under warranty though make em give you a new one
Behringer... | Answered on May 09, 2011
Return the amp under warranty immediately. This is NOT a normal thing.
Behringer... | Answered on Apr 24, 2011
No you can't quite do this since the EQ's are right before the power amps in the signal flow. The monitor output would drive two 8 ohm speakers daisy chained at roughly 300 watts RMS... I can't imagine needing more than that for a venue that is within the capabilities of this unit.
You can drive both power amps by the monitor output by setting the mon/main function on the switch and using a short TRS cable jumper between MONITOR PREAMP OUT and the RIGHT POWER AMP INPUT jack. Drive your mains from the LEFT PREAMP OUT. The EQ's will ONLY affect the monitors. Use an external EQ if you need to EQ the mains with this connnection. Use TRS balanced cables to the main amp and CONNECT all interconnected equipment to the SAME power source or receptacle, even if it means running an extension to the mixer.
Behringer... | Answered on Apr 05, 2011
In order to help you we would need the make and model of the mixer.
Behringer Music | Answered on Apr 30, 2020
Behringer recommends using a shielded CAT 5e cable with Ethercon connectors wired to the T568B standard to connect the two. Also you need to make sure that the board is completely powered on before turning on the S32 for proper connection. Make sure you are connecting between the Aes50A ports. When connected you should be able to see a green light next to Aes50A in the main screen. Then you will need to properly route the channels.
Behringer Music | Answered on Nov 13, 2019
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer.
Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes?
The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
Behringer Music | Answered on Oct 23, 2019
You have given in detail which is helpful
Behringer Music | Answered on Oct 16, 2019
Behringer PMP2000 800 Watt 10 Channel Powered Logo
20 questions posted
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
behringer pmp2000 now only giving output
  • Music
