20 Most Recent Crate FlexWave FW120H Guitar Amp Head with DSP, 120W Questions & Answers
Reverb spring end broke. you can bend a new loop with pliers. There is a post sticking up in side the metal case that hooks around the end(s)
Crate FlexWave... | Answered on Aug 21, 2019
its the reverb tank spring, look where it is connected on the other side. this will give you an idea as to where it was connected. solder it back on.
Crate FlexWave... | Answered on May 19, 2016
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Crate FlexWave... | Answered on Feb 21, 2013
Both those LIKELY run on a 5 volt supply within the unit. Check for the presence of that voltage... some new stuff MIGHT be 3.3 volts DC, but you should find those voltages. If missing, it may be a shorted electrolytic filter cap OR the filter cap associated with creating the 5 volts from the supply. You really need the schematic for this... try to procure one.
Crate FlexWave... | Answered on Sep 13, 2011
Solid state amps are very subject to blowing out the output transistors if speaker leads get shorted. Take it in for repair.
Crate FlexWave... | Answered on Aug 31, 2011
https://www.google.com/search?q=Schematic+crate+g60xl&oq=Schematic+crate+g60xl&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Crate Music | Answered on Dec 01, 2020
Request from Crate
Crate Music | Answered on Nov 01, 2020
bad output transistors.
Crate Music | Answered on Aug 21, 2019
Clean the volume and tone pots with de-oxit cleaner
Crate Music | Answered on May 02, 2019
Try with a on/off footswitch Wrong cable, or bad PCB connection switch on main tone board.
SLM sold the company years ago to Loud audio. Its only supported online now. Loudaudio.com
Power supply capacitors failed. This is a common problem with 1990's crates, also the power on "POP".
https://www.amprepairparts.com/schematics.htm
Use the GX-65, its the same preamp shopwn just with 2 power amp sections
There is a short somewhere, check your wiring and solder points.
Crate Music | Answered on May 01, 2019
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
Crate Music | Answered on Mar 03, 2019
1. Sounds like it's the input jack., but it could be the volume knob. Have you tried turning Gain1 and Gain 2 or the Clean Channel volume? Try them first when you're plugged in to the jack on the left , then when you're plugged in the back. If none of these work, it's most likely the preamp. 2. Even if the preamp is shot, there's a quick fix - get a guitar preamp or an effects pedal - they have volume and tone controls. 3. Finally - many pros just plug into the aux jack(on the rear panel) and control the volume and tone through their instruments. Hope one of these works. Good Luck.
Crate Music | Answered on Dec 26, 2018
Crate FlexWave FW120H Guitar Amp Head with DSP, 120W Logo
Popular Tags
9 questions posted
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
View Most Popular
Crate Music
  • Crate Music
Most Popular Question
loose spring crate amp head
  • Music
