20 Most Recent NetGear RO318 Router Questions & Answers
When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
NetGear RO318... | Answered on Nov 09, 2017
Check with your ISP also may be they are not permiting to your router's MAC address need to change their.
NetGear RO318... | Answered on Apr 01, 2010
Here's the manual for the Netgear router
ftp://downloads.netgear.com/files/netgear1/RO318_RefGuide.pdf
NetGear RO318... | Answered on Sep 30, 2009
In that case reset the router and reconfigure it with the ISP settings,,there s a smallbutton on the back panel for hard reset but make sure if the router is old reseting might damage it..best of luck
NB>if routers are old then power surge might damage it
NetGear RO318... | Answered on May 15, 2009
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
NetGear RO318... | Answered on Feb 19, 2006
You may have to remove proxy settings on your Internet browser (i.e.: Netscape or Internet Explorer). Or, remove the dial-up settings on your browser. The PC may not have received an IP address. Restart the PC or run the ?winipcfg? utility to dynamically assign the IP address (?ipconfig? for NT users), and then launch the browser
Wait for Java to finish loading before typing the username and password. Internet Explorer displays the router's login page before the accompanying Java applet is fully loaded. If you attempt to submit a login before the applet is loaded the router will reject it. Netscape browsers do not have this issue because they do not display the login page until the Java applet is fully loaded. If this does not solve the problem, close and relaunch the browser.
If the servers have simple names like 'mail' or 'news', the problem may be that the ISP's domain suffix is not being added to these names before DNS lookup. Add your ISP's domain suffix as Domain Name in the RO318's System menu. In addition, the ISP may be looking for a particular host name for your account, in which case you should enter the host name as the System Name in the RO318's System menu. Example: Consider the following account with the ISP "earthlink.net". 1. Host Name: C-223344-A 2. Domain Name: www.earthlink.net Mail Server mail Although the ISP lists the name of their mail server as 'mail', the fully expanded name is actually: mail.earthlink.net If the ISP automatically provides the domain suffix to your router, the router will append the domain suffix to DNS requests. If not, you can try one of these methods: 1. In each application (such as mail client or news reader), list the fully expanded server name, 2. Manually configure DNS parameters in the network settings of each of your PCs, and enter the domain suffix manually.
https://www.youtube.com/watch?v=EkOo_gs5vBw
NetGear... | Answered on Apr 09, 2020
https://www.google.com/search?sxsrf=ALeKk03PaBlhbIut8HXkWqf7V-HpEgzhdg%3A1585151795759&source=hp&ei=M397XuehLInDlwSL3664Aw&q=Netgear+extender+setup&oq=Netgear+extender+setup&gs_l=psy-ab.3..0l10.2265.2265..3448...2.0..0.245.245.2-1......0....2j1..gws-wiz.....10..35i362i39.kIdrteiVKc0&ved=0ahUKEwinh8zN_rXoAhWJ4YUKHYuvCzcQ4dUDCAU&uact=5#kpvalbx=_1oF7XuuSHITyasH6vLAI26
NetGear... | Answered on Apr 06, 2020
The important thing is the voltage and to equal or exceed the current.
Your drive required 2 Amps so a 2.5 Amp power supply will be fine.
What about the 5 Volt logic supply ... is that used on your drive I wonder. Some do, some don't.
CONTACT THE ROUTER SERVICE PROVIDER MY NETGEAR HAD IT ON THE BOTTOM OF ROUTER
NetGear... | Answered on Mar 16, 2020
READ THE DIRECTIONS THEY PROVIDED YOU
Install the correct win 10 drivers from netgear.
NetGear... | Answered on Feb 05, 2020
Go to the Netgear website and check for the support link, go to that link and look for firmware updates for your model. They install from the computer side of the LAN, you may need to run CAT 5 cable to the inputs to do it.
NetGear... | Answered on Dec 20, 2019
NetGear RO318 Router Logo
11 questions posted
Top NetGear Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
very slow internet after power outage
  • Computers & Internet
