20 Most Recent Yamaha DGX-230 Portable Grand Piano Questions & Answers
You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory. decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
Yamaha DGX-230... • Answered on Jul 20, 2014
There is power from the power supply if the logo is on the screen, although it could be it isnt providing full current. Whilst the logo is displayed the machine carries out a number of checks to ensure it is working correctly. Once these checks are completed it moves to showing the voices etc. If it hangs it has found a fault and further investigation will be required.
Yamaha Music • Answered 8 hours ago
My Yamaha P85 had a no sound problem too. I replaced the two 100uf capacitors at locations C216 and C217 on the board where the DC power plug connects. Fixed it right up.
Yamaha Music • Answered on Dec 08, 2020
Order the service manual from Yamaha.
Yamaha Music • Answered on Nov 12, 2020
Go to the menu and the settings, language & Keyboard Touch Input. Text Input under an other setting make sure that you have the sound feedback checked. If that is checked and its still not working try restarting your device. Sound feedback is checked; no sound for keyboard or menu/app selections. When no sound is output even though the power is turned on, check the following points. Make sure that the master volume is not set too low. Set it to an appropriate level using the slider or knob. Make sure that nothing is connected to the headphone jack on the keyboard.
Yamaha Music • Answered on Aug 08, 2020
Hi Phil! If you find the schematic for Yamaha GA 15 ii, please let me know as I was looking for it as well. I was playing the guitar for a long time but due to all this college stuff, I had no opportunity to play the music at all and then my friend asked why not try these out and I have paid a professional writer to do my homework. Thanks to this writing service, I have time to play guitar but now I cannot find a schematic for Yamaha GA 15 II guitar amplifier.
Yamaha Music • Answered on Mar 29, 2020
https://www.youtube.com/watch?v=rgCplnREnXs
Yamaha Music • Answered on Mar 06, 2020
Do the lights come on? Have you tried the headphone output as well as the line output(s)? Is the volume turned up? Do you have it plugged in with the original Yamaha AC adaptor? https://usa.yamaha.com/support/manuals/index.html?l=en&c=keyboards&k=DGX505 Owners manual in the link.
Yamaha Music • Answered on Nov 04, 2019
seems to be a standard acoustic setup to me. If it doesn't have all the string pins in it, you'll need to get some. you simply pull out the pin, put the string in, then wind it up on the machine heads (tuners) On this one you may need to put the strings through from the inside, I'm not sure about this particular model. I like a double wrap to start on the bass strings, but that's a choice I make. You could go with nylon strings, get ball end, they're easier to use than plain. It takes a bit of know how to do plain, thy have to be wrapped just right on the pins.
Yamaha Music • Answered on Nov 02, 2019
Hi If you are talking about cleaning the rubber contacts I wouldn't bother. Once they start to fail then it is best to replace them. You can do this either for the octave giving problems or best to replace complete set. Main part is VY84670R your piano has 6 octaves of these. with a shorter part at either end.
Yamaha Music • Answered on Oct 24, 2019
Yes you may use it as stand alone piano. Usually everytime you will power ON any yamaha psr model piano will appear as default voice.
Yamaha Music • Answered on Oct 19, 2019
This should help you trace the wires image1-hkvzf2teq5seftdrfl2ij2t0-4-0_0.jpg
Yamaha Music • Answered on Sep 27, 2019
Hi the blue screen with lines is normally as a result of the ribbon cable which has contacts on failing. The remedy is normally to replace the simple the screen assembly the parts for this are around £300 but there would be significant labour to add to this. i would suggest talking to a local Yamaha technician Becketts Music Ltd
Yamaha Music • Answered on Sep 17, 2019
Yamaha DGX-230 Portable Grand Piano Logo
6 questions posted
Top Yamaha Music Experts
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
am able delete demo songs keyboard more
  • Music
