20 Most Recent Korg miniKP mini KP KAOSS PAD Effect Processer Sampling Questions & Answers
To restoring Korg M50 to it's factory settings, first press the [MODE GLOBAL] button to enter Global mode. Then, press the [MENU] button, and choose "Load Preload/ Demo Data". When a dialog box appears, select "All Preload PCG" and then press the [OK] button. Finally, when a dialog box appears on the display, press the [OK] button again to execute the function.
Warning! This operation will cause restore any or all of the Programs, Combinations, Drum Kits, User Arpeggio Patterns, and Global settings to their original factory settings. Do not use this function unless you are certain that you want to do this. Hopefully the article of "Reset Korg M50 88-Key Keyboard Workstation" can help you.
Korg Music | Answered on May 16, 2020
https://www.google.com search of the internet gives the following result:
https://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-x5-x5d-dr/
How to Initialize (reset), and preload on the Korg X5/X5D/DR
  • Article #16230
  • Updated on Apr 27, 2007 at 12:00 AM
Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Korg Music | Answered on Feb 27, 2020
NOT THAT I AM AWARE OF
Korg Music | Answered on Jan 30, 2020
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
Korg Music | Answered on Nov 21, 2019
6. Playback
(1) Set channel 1 to play.Turn the REC/PLAY key on. Then press the channel key of track 1 (the track you just recorded) to set it to Play (key lit green).
(2) Return to the beginning of the song.Hold down the STOP key and press the REW key to return to the beginning of the song (?p.37 "2. Location").
Korg Music | Answered on Jul 12, 2019
I will assume you want to sync the two as one. I have one of these sitting in a closet. The 3200 will record 12 tracks at a time if I remember correctly. I believe the Korg will sync to Midi Time code. I just wonder if the midi implementation allows for start and stop code. Anyway, I found this information:
x2. MIDI messages used by the D3200 Note On (Note, velocity), aftertouch, pitch-bend:
The D3200 uses these messages to control effects.
Program change:
The D3200 uses these messages to switch scenes.
Control change:
The D3200 uses these messages to control mixer and
effect parameters.
MMC (MIDI Machine Control):
MMC messages can be transmitted from the D3200 to control an external MMC-compatible sequencer or recorder. MMC messages received from an external sequencer or recorder can be used to control the D3200.
MTC (MIDI Time Code):
The D3200 can transmit or receive MTC messages to
synchronize with an external sequencer or recorder.
MIDI Clock:
The D3200 can transmit MIDI Clock. It can also receive MIDI Clock if you have selected MIDI Clock for the tempo track and are recording the tempo track.
Email Korg customer service in your country for advice, or search the manual if you have it.
Korg Music | Answered on Jul 07, 2019
Korg miniKP mini KP KAOSS PAD Effect Processer Sampling Logo
Popular Tags
0 questions posted
Top Korg Music Experts
Poul Brinchs Larsen
Becketts Music Ltd
Becketts Music Ltd
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
service manual korg pa600
  • Music
