20 Most Recent Numark Industries Numark X6 Two Channel Professional Digital 10" Mixer Questions & Answers
in your system preferences click on sound and adjust the settings you need.
Numark... | Answered on May 09, 2011
/it's most likely a defective fader, but before replacing it, get a can of Deoxit5 or fader cleaner and spray inside the fader, then move it the full length os travel about 20 times to see it that clears it up.
Numark Music | Answered on Jul 10, 2016
sure tons!!! most every music shop that I ever been in (and that's a lot !!) that sold instruments and stuff has either an in house tech or a "guy" they go to , ask em as they get perks for referrals
Numark Music | Answered on Jan 05, 2016
Most turntables require a new drive belt. The cartridge sometimes needs replacing. Cahngers require much more maintenance. Hardly anybody does this anymore... but if belt has deteriorated, that is DIY as you can find suppliers of the belt online.
Numark Music | Answered on Aug 19, 2011
https://blog.caristaapp.com/mlb-evo-testers-wanted-q7-q8-a8-827e78827e0f
Music | Answered 3 days ago
How do I hey the headphones to work ?
Music | Answered on Jan 19, 2021
Video and text based help on the link
https://www.google.com/search?q=Ypg-625+key+is+stuck+upward
Last post will not let me put pictures for some reason so mine says Ibanez 61-12491
Music | Answered on Jan 09, 2021
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Music | Answered on Dec 20, 2020
This is a common problem with Bugera. And, unfortunately they are made by Behringer who is known to have the worst customer service of all and do not follow through on their warranties.
Music | Answered on Dec 12, 2020
Request the manual from Rogue.
Music | Answered on Dec 07, 2020
It's here $16.15
TOP+ AC Adapter Charger for TC Electronic Vibraclone ...
www.amazon.com > TOP-Adapter-Charger-Electronic-...
Amazon.com: TOP+ AC Adapter Charger for TC Electronic Vibraclone Rotary Effects Pedal Power Supply Cord Mains PSU: Electronics.
Music | Answered on Dec 02, 2020
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Music | Answered on Nov 25, 2020
Contact Clavinova directly to request the manual.
Music | Answered on Nov 11, 2020
Did you get it fixed?
I have exactly the same problem!
Music | Answered on Oct 26, 2020
Numark Industries Numark X6 Two Channel Professional Digital 10" Mixer Logo
5 questions posted
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rhodesworks
Steve Pack
Steve Pack
Are you a Numark Music Expert? Answer questions, earn points and help others
View Most Popular
Numark Music
  • Numark Music
Most Popular Question
just bought new
  • Music
