20 Most Recent LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
Can read cds but no
1) Clean your DVD lens with a cotton.
2) Change the data cable.
If these methods doesn't then there might be problem in lens.
7/8/2011 7:17:28 AM • LG... • Answered on Jul 08, 2011
Helo.I have lg combo gcc4521b.it
The drive is failing, time to upgrade! NewEgg and Amazon have burners available cheaply.
5/5/2011 7:35:17 PM • LG... • Answered on May 05, 2011
Works not
make sure that the cd-rw/dvd-rom burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
1/9/2011 9:20:20 AM • LG... • Answered on Jan 09, 2011
Do you have help screens
Hi pmhartman,
You can download documentation here:
http://www.retrevo.com/support/LG-GCC-4521B-DVD-Drives-manual/id/440dj293/t/2/
Hope this helps you.
12/23/2010 5:47:17 PM • LG... • Answered on Dec 23, 2010
After selecting files to burn
Hi.
When you put in the DVD-RW and want to add files to it, it should ask you whether you'd like to add data to the current session. You can only do this however if you haven't finalized the disc. Rewritable discs save data in sessions, as long as you don't close or finalize the disc you can keep adding files until it's full.
Hope this helps.
12/22/2010 1:33:08 PM • LG... • Answered on Dec 22, 2010
Just bought and installed LG
Assuming this is the only cd drive you have, just go to the device manager and remove/uninstall anything under "DVD/CD Rom Drives" then restart. It should get picked up and recognized properly. It took a couple of restarts to work. For reference, if only have the LG GH22NP20 installed, what appears in device manager are 2 items... (1)HL-DT-ST DVD-RAM GH22NP20 SCSI CdRom Device... (2) KU1051Q EAG855E SCSI CdRom Device... In case you have multiple cd drives, this should help.
9/29/2010 12:22:10 AM • LG... • Answered on Sep 29, 2010
2answers
Connect burner and restart Windows Media Player
Run REGEDIT
Select {4D36E965-E325-11CE-BFC1-08002BE10318} at the end of the following path:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters do an Edit/Delete
In right pane select LowerFilters do an Edit/Delete
Exit REGEDIT
Right click MY COMPUTER
Properties
Hardware
Device Manager
Uninstall CD/DVD player/burner
Restart the machine and it will find and reinstall the burner
NOTE: if you’re uncomfortable deleting registry entries, rename them (e.g., w/ “.SAV” extension)
10/28/2009 9:45:10 PM • LG... • Answered on Oct 28, 2009
I require the driver for cd-rw / dvd-rom drive
go to LG's website and see if you can download what you need from there, if you can't then you might need to buy it from them instead.
7/22/2009 4:39:26 PM • LG... • Answered on Jul 22, 2009
Connect a burner and restart the player what do i
make sure you have the correct software..i.e nero
7/13/2009 7:40:09 AM • LG... • Answered on Jul 13, 2009
Open REGEDIT
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters - do an Edit/Delete
In right pane select LowerFilters - do an Edit/Delete
Exit REGEDIT
Properties
Hardware
Device Manager
Uninstall your CD/DVD player/burner
Restart the machine - it will find and reinstall your burner and you'll be good to go
Note: if your uncomfortable deleting registry entries, rename them (e.g., w/ ".SAV" extension)
7/1/2009 2:19:25 AM • LG... • Answered on Jul 01, 2009
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
12/26/2008 6:58:43 AM • LG... • Answered on Dec 26, 2008
Xp my cd rome dont'
Pleae check data able and power cable
12/25/2008 1:21:22 AM • LG... • Answered on Dec 25, 2008
3answers
LG Burner Device Driver
lg /com ? or u meen uw ant nero software to burn with it ? nero.com then or lg.com suprt for your model
12/13/2008 5:58:03 PM • LG... • Answered on Dec 13, 2008
3answers
My LG model LW1516ERY7 Air conditioner is beeping and I don't know what it means. Can you help?
https://www.youtube.com/watch?v=IHL1wxni7tY
7/19/2022 10:19:55 PM • LG Computers &... • Answered on Jul 19, 2022
Touch buttons not working on LG 47lm4600 n I have no remote
Hello, hope to find you well. You can try the LG ThinQ app for smartphone, that will allow you to control your TV. Hope it helps.
7/5/2022 9:34:03 PM • LG Computers &... • Answered on Jul 05, 2022
How to fix LG monitor that doesnt turn on?
If you get a notice on the screen that the feed is not detected you may want to replace the feed cable to your device. If that doesn't work try the monitor on another device and see if the problem follows.
6/20/2022 2:58:19 AM • LG Computers &... • Answered on Jun 20, 2022
My lg lcd monitor shows STROMSPARMODUS on mid of screen...can any one tell 2 fix it.??
Hello! If you see that problem it's Automatically It's ok. It's maybe because your 1280x1024 lcd is little bit bigger than the original size! Have a nice day!
4/21/2022 10:56:19 AM • LG Computers &... • Answered on Apr 21, 2022
LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo) Burner Logo
19 questions posted
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
after selecting files burn
  • Computers & Internet
