20 Most Recent NetGear DGN1000 Wireless Router Questions & Answers
Can't upload files or send emails via wifi with dgn1000 router
Has this ever worked and now something's changed, or have you never been able to make it work, please?
11/29/2017 9:14:58 PM • NetGear DGN1000... • Answered on Nov 29, 2017
Quality of Service
There is no QOS setting on this router. See Manual. http://www.downloads.netgear.com/files/GDC/DGN1000/DGN1000_UM_29Feb12.pdf
3/9/2015 4:36:28 PM • NetGear DGN1000... • Answered on Mar 09, 2015
Runtime error
Look at the back of the router it gives all the default information to use on a web browser (to avoid the runtime error) Press the Restore Factory Settings button, on the bottom of the unit, for 6 seconds. Connect via a Ethernet cable and put in the gateway address of 192.1.168.1 to the web browser to see the login screen. User name is admin, password is password. Then you can reconfigure the router to your set-up. Here is the manual. http://www.downloads.netgear.com/files/GDC/DGN1000/DGN1000_UM_29Feb12.pdf
3/9/2015 4:34:41 PM • NetGear DGN1000... • Answered on Mar 09, 2015
Lost my Wireless name (SSID) lost my Security
1. Open your internet browser.
2. Type in 192.168.0.1 and press enter.
3. When prompted, type in admin for username and password for password. That should get you into all of the settings, where you can view your wireless network's SSID and security passphrase.
4. CHANGE your username and password. This is how hackers access your network!
5/27/2014 7:14:28 AM • NetGear DGN1000... • Answered on May 27, 2014
2answers
How to do port forwarding
http://portforward.com/
12/9/2013 2:23:27 PM • NetGear DGN1000... • Answered on Dec 09, 2013
Ipad can not connect help
Is there any other wireless device in the network?Can you connect your computer to the wireless network?What error message do you get?I will suggest you to read this article for iPad wifi setup
11/27/2013 4:31:22 PM • NetGear DGN1000... • Answered on Nov 27, 2013
Cant access router
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -http://192.168.0.1The default login = adminThe default PW = passwordYou can now change the default admin password and configurethe wireless settings.Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.Apply these settings to the wireless card in your laptop/computer.To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
11/27/2013 4:28:53 PM • NetGear DGN1000... • Answered on Nov 27, 2013
How do i change password
to change the password on a netgear, you first need to secure or make sure that you are connected to it. be it wireless or hardwired. after ensuring that your laptop is connected, open a browser, and type 192.168.1.1 or www.routerlogin.net, then it would ask you for a username and password. username is " admin " password is " password " then it would take you now to the netgear page. on the left side of that screen, click on wireless settings, then you can start changing your password in security option. then click apply.
11/27/2013 4:27:03 PM • NetGear DGN1000... • Answered on Nov 27, 2013
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
11/27/2013 4:25:44 PM • NetGear DGN1000... • Answered on Nov 27, 2013
Dell xps
Can you be more specific?
5/15/2013 2:18:50 AM • NetGear DGN1000... • Answered on May 15, 2013
I do not know the password for the modem
Modems don't have a password, unless you have DSL with a password provided by your ISP. Then only you ISP can manage your account.
1/30/2013 10:01:01 PM • NetGear DGN1000... • Answered on Jan 30, 2013
0answers
Wierless router not responding
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
2/12/2012 10:41:33 PM • NetGear DGN1000... • Answered on Feb 12, 2012
How to change the channel on my router?
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under wireless there is channel option8. the best channels to use are 6 and 11 then save it
12/29/2011 1:02:17 AM • NetGear DGN1000... • Answered on Dec 29, 2011
I have a problem with my router login.I have tried
If the router ssid reads virginmedia.... then you have not reset the router. The default name for a Netgear router is Netgear.Push the reset button in (on the back of the router) and hold it for at least 15 seconds or until the power light flashes.Now the username and password and SSID should be reset to the default.
10/23/2011 10:08:50 PM • NetGear DGN1000... • Answered on Oct 23, 2011
Ive currently got the netgear
Check the following and then try the solution:
1. Do you have other wireless devices connected?
Yes, go to solution #1, if you know the SSID then try solution #2
No, go to step 2.
2. Are there any wifi connection listed in range?
No, go to step 3
3. Go to a location were you know there is a wifi connection, can you see this connection in the wireless assistant?
No, go to solution #2
#1 my thought is you are not sure of what the SSID is, so place the laptop next to the Netgear router and chose the best wifi signal to connect to in wireless assistant.
#2 There is a switch/or button on the laptop to turn on the wireless. It is normally somewere on the side of the laptop, turn it on and it should glow blue. Now try to connect to your router.
Hope this helps
7/21/2011 6:50:26 PM • NetGear DGN1000... • Answered on Jul 21, 2011
NetGear DGN1000 Wireless Router Logo
37 questions posted
Top NetGear Computers & Internet Experts
Mike
Donivan Wise
Narseman
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
ipad not connect help
  • Computers & Internet
