20 Most Recent Fisher and Paykel DD60DCHB6 Built-in Dishwasher Questions & Answers
0answers
F9 error
Be the first to answer 12/4/2011 7:40:57 PM • Fisher and... • Posted on Dec 04, 2011Be the first to answer
The top drawer of my fisher Paykel is disabled, will the bottom drawer still work?
no info generic answer can not receive an answer to an unknown-- fixya does not have mystics or crystal balls
1/30/2023 3:18:29 PM • Fisher... • Answered on Jan 30, 2023
3answers
F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
1/2/2023 2:31:37 AM • Fisher... • Answered on Jan 02, 2023
2 drawers fisher n Pykel dishwasher top stuck on rinse. Tried cleaning the control and unplugged. How to open the panel and instruction how to swap the censor to find the problem..
What model? do a Google search for the service manual for your machine, it will detail how to access the service and testing part of the machine.
2/8/2022 1:52:08 AM • Fisher... • Answered on Feb 08, 2022
2answers
Top drawer of DD60DCX7 Fisher Paykel DishDrawer won't drain properly.
https://www.youtube.com/watch?v=kocA5kOA70I&list=PLphk3KpL9obhu4A1EytgMnE9tZJXi2Yfl&index=12&t=0s https://www.hunker.com/12160071/how-to-unclog-a-fisher-paykel-dishdrawer-drain
4/18/2020 11:21:15 AM • Fisher... • Answered on Apr 18, 2020
F2 error code on a Fisher & Paykel dishdrawer DS605. We have replaced the rotor motor with a new one, but the error code will not go away. Drainage hose was also split and has been replaced.
Hi Dan-I found this link.https://www.fisherpaykel.com/vault/pdfs/pdf_usecares/599864A_DD60_userguide_CN(EN).pdfIf you are looking to reset the error code. On page 28 "Fault Codes", it talks about "How to attend to a fault code".Hope this helps.I also found this youtube video on Fisher & Paykel dishwasher repairs.https://www.youtube.com/playlist?list=PLLkJYbdOr3lovxlEUZUJRSzBKsA2-6giDHope this helps.
11/29/2019 1:41:39 PM • Fisher... • Answered on Nov 29, 2019
I have a Fisher paykel late model Dwk60 dishwasher, that keeps getting the error code E30, flood switch activated with the alarm and won't reset, I found online that you tilt the machine backwards
You have to turn the power off, clean that cesspool drain area thoroughly, dry all around the door seal, and tip dishwasher backwards. Then the flood switch resets and the E30 error disappeared for me.
7/1/2019 6:32:30 AM • Fisher... • Answered on Jul 01, 2019
So i have a fisher pykal double drawer dishwasher. The top drawer doesnt work. Still has power...but doesnt make the chime when u pull it open. No code is being trown. Doesnt start gives a chime that says...to bad...help
Although I'm not familiar with this model, it sounds like a switch is stuck or misaligned. With most electronic things, there's a physical toggle switch (sometimes 2 magnetic points, similar to a window security system) located somewhere along the drawers tracks or latch or at the back. Try to find it and see if it still freely moves. If it does than most likely the switch has failed and needs replacement. Hope this helps and good luck!
1/11/2019 1:28:31 PM • Fisher... • Answered on Jan 11, 2019
Hi, how do I fix error code F1 of a fisher & paykel draw dishwasher??
The F1 error on a Fisher and Paykel dishwasher means the flood switch was activated for seven seconds or longer. ... The dishwasher's flood switch could activate because the water is leaking around the heater plate. It would still eventually show up somewhere, though a leak like that would kill the heater plate too.
11/5/2018 12:49:46 AM • Fisher... • Answered on Nov 05, 2018
Fisher & Paykel Dishwasher Model 920 has controller 521793p - tripping outside meter board circuit breaker after it has been operating for only a couple of minutes. ?? replace/repair module?
maybe circuit breakers trip from excessive current and poor insulation or moisture around electrical contacts call in an electrician to test the unit first and then repair / replace what is found to be faulty remember that the power point for the unit may also be on the house circuit that is having a problem unit somewhere else that is causing the fault
10/3/2018 5:16:36 AM • Fisher... • Answered on Oct 03, 2018
Fisher packed dishwasher dd603
If the panel display on the lower drawer is lit and you can select the program then most likely the water inlet valve is fault and needs replacement. But if the panel is dark and none of the buttons operate then the power to the drawer is cut off. This can be due to a number of reasons including the power board at the base loosing one power circuit or the thermal fuse in the drawer is blown. Please provide model number of dishdrawer unit and also please describe what is actually happening.
3/7/2018 12:43:19 AM • Fisher... • Answered on Mar 07, 2018
Service manual for 913T dishwasher
Do You want a Service Manual or a User Manual. Both are for different purpose.Please let me know your email id to send Service Manual.
1/21/2018 6:27:14 AM • Fisher... • Answered on Jan 21, 2018
Fisher and Paykel DD60DCHB6 Built-in Dishwasher Logo
2 questions posted
Top Fisher Dishwashers Experts
vince
Paul
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Fisher Dishwashers
  • Fisher Dishwashers
Most Popular Question
fix error code f1 fisher paykel draw
  • Dishwashers
