20 Most Recent Medion MD-1704 PC Desktop Questions & Answers
My Medion MD-1704 Desktop does not recognize my Hard Disk Drive nor my CD Drive, why?
it could be loose, unplug your box and disconnect the devices and reconnect them again.
8/27/2014 3:03:53 PM • Medion MD-1704... • Answered on Aug 27, 2014
Front bezel
In a lot of pc,s the front comes off if not open the case and you will be able to see it from there or you should do
4/20/2014 1:15:28 PM • Medion MD-1704... • Answered on Apr 20, 2014
Front bezel exploded view medion md 1777
Hi Robert, please don't multipost. Someone will answer your question when they have the information.
4/2/2014 11:50:22 AM • Medion MD-1704... • Answered on Apr 02, 2014
0answers
0answers
2answers
Computer won't turn on. Blue flashing light.
The blue light blinking indicated that your processor if faulty.So please check your processor. Take it to tech department for new processor.
I hope this solution has been helpful.
11/19/2013 11:47:29 AM • Medion MD-1704... • Answered on Nov 19, 2013
Very very very slow download speed
How to put wifi on old emachine computer
6/19/2013 7:26:29 PM • Medion MD-1704... • Answered on Jun 19, 2013
WHAT KEY IS REQUIRED FOR RECOVERY OF MEDION MT 7 PC
From the Setup CD-ROM 1. Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD. 2. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. 3. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. 4. When prompted, type the Administrator password. 5. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command. 6. To exit the Recovery Console and restart the computer, type exit. If you have already installed the Recovery Console 1. During Startup, select Recovery Console from the startup options menu. 2. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. 3. When prompted, type the Administrator password. 4. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command. 5. To exit the Recovery Console and restart the computer, type exit.
8/29/2012 5:16:44 PM • Medion MD-1704... • Answered on Aug 29, 2012
No video signal
pls check your RAM. clean and fix it. your video problem will solved.
8/30/2011 1:51:15 PM • Medion MD-1704... • Answered on Aug 30, 2011
My medion has a tv card but cant watch tv
What you need do is install the drivers/applications that are necessary for your TV card to work. Find these drivers/utilities on the CD disk that came with your computer.
If you do not have access to the CD disk, find the drivers on the internet using the makers name and model number of the TV card. This info can be found on the TV card itself.
Take care!
damnor01
8/13/2011 12:27:42 PM • Medion MD-1704... • Answered on Aug 13, 2011
What drivers were used for the ethernet controller
drunk ones if it crashed
6/22/2011 8:09:09 PM • Medion MD-1704... • Answered on Jun 22, 2011
2answers
My medion home computer was
Try this if using windows vista or 7:
1)when you switch on the computer press F8 key on keyboard,
a menu should come up,
2) Select repair computer and press enter
3) Chose startup repair
6/17/2011 8:28:57 AM • Medion MD-1704... • Answered on Jun 17, 2011
Windows vista, microsoft has stopped it from
this is because the drivers for the graphics card are reporting back that the card is failing. This may not be the case but might be corrupted drivers. uninstall the card through the device manager and then scan for hardware changes so windows reinstalls it. if that doesn't work, download the drivers from the ati website and try again. make sure that all fans and heatsinks are clean and unblocked using a brush and compressed air (not the vacuum cleaner). if all this fails, it may be the card.
5/30/2011 9:45:45 PM • Medion MD-1704... • Answered on May 30, 2011
2answers
No power at all
Common problem with this model. The power supply goes bad like emachines. Make sure the power switch on the back by the plug is turned on first. I have seen them powered on and still not supply power to the motherboard. For that model you need an ATX power supply replacement.
5/15/2011 7:14:00 PM • Medion MD-1704... • Answered on May 15, 2011
Dont need your help i will take it to pc world
If you were smarter, you fixed it by your hands, using our tips.
5/15/2011 7:10:15 PM • Medion MD-1704... • Answered on May 15, 2011
Beep and blue flashing light
in that case you need to open the tower or CPU and reseat RAM and graphic card if you have 1
and then try to start the computer
it should work
and if you still get beeps.
and can try to plug memory card 1 by 1
if you have more than 1 memory card
if the computer starts with 1 memory card
then it could be the issue with the memory card
if not then the slot on the motherboard is gone bad
and the motherboard needs to be replaced or repaired
3/28/2011 4:30:38 PM • Medion MD-1704... • Answered on Mar 28, 2011
Start up
This is a rather vague question. Not sure at to what is going on with this problem so I will just assume what you need is you are having a crash with no being about to start up your computer for some reason all I can suggest since I have no further information is go ahead and shut the computer down and unplug it from the wall. Press the power button until you see it flash.
Then plug the computer in and restart your system. This will reset drivers and the computer to its default state. Then try it from there restart the computer. If this does not work, you can perform a system restore back to an earlier time. This would be my best answer for this question.
Depending on your Operating system XP or Vista or Win 7 you can go to start-run-type MSCONFIG then go in and select restore computer look for restore computer for an earlier time. If this is not already set up you cannot go back if it is you will see a little calendar if you can get there at all. Select an earlier date that you new you had no problems. If this does not work insert the either restore disc or the WinXP or Vista or the Win 7 disc in the CD or DVD ROM drive and restart the computer and do a complete wipe and re-install of your operating system from the System Boot Disk it should be set to Load from CD or DVD ROM as the first boot.
If not you will need to go into the BIOS and set the BOOT section to boot from the DVD or CD ROM as the first boot and hard drive as the second boot device. This will ensure that the disk that is inserted will boot first follow the on screen instructions. I hope this assisted you with this question. John
2/7/2011 2:11:45 PM • Medion MD-1704... • Answered on Feb 07, 2011
Have a medion md1704 needs sound drivers for it
Click on the link below and download the driver utility program which will help you install the audio drivers
Driver utility program
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
2/1/2011 12:50:40 AM • Medion MD-1704... • Answered on Feb 01, 2011
Medion MD-1704 PC Desktop Logo
64 questions posted
Top Medion Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Medion Computers & Internet
Most Popular Question
key required recovery medion mt 7 pc
  • Computers & Internet
