Code 3
The driver for this device might be corrupted, or your system may be running low on memory or other resources. (Code 3)
Here are some things that you can try to resolve this problem.
Close some open applicationsIf the computer has insufficient memory to run the device, you can close some applications to make memory available. You can also check memory and system resources, and the virtual memory settings.
- To check memory and system resources, open Task Manager. To open Task Manager, press CTRL+ALT+DELETE, and then click Task Manager.
- To check virtual memory settings, right-click My Computer, click Properties, click the Advanced tab, and then click Settings in the Performance area.
Uninstall and reinstall the driverThe device driver may have become corrupted. If the driver is corrupted, uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
- On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
- Restart your computer.
- Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Install additional RAMYou may have to install additional random access memory (RAM).
