20 Most Recent Microtek ScanMaker V6UPL Flatbed Scanner Questions & Answers
Unfortunately, Microtek doesn't support the V6UPL for any Windows OS beyond XP. The drivers are available here: http://support.microtek.com/downloads/bycategory.phtml?slct_tbl=1&slct_mdl=2 .
What version of Windows 7 are you running? Click Start > Control Panel > System and Security > System. If the version name ends with x64, you have the 64-bit version; otherwise you have the 32-bit version.
If you have the 32-bit version, try using the driver from the above site with the compatibility mode. Right click on the .exe file and choose Properties. Then select the compatibility tab. Set the program to always run in the compatibility mode for XP. Then right click again and choose Run as administrator. (You may need to disconnect the data cable and uninstall the Unknown device before trying to install the XP driver).
This will probably not work for Win7 x64. There are workarounds that you can use. You need to connect the scanner to a computer running an older version of Windows. This can be a physical second computer, a dual boot computer or a computer running a virtual version of the older OS. If you have Win7 Pro or Ultimate, or upgrade to one of those versions, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. Then install the XP scanner driver in the XP mode program as if that is the only computer running. The only issue is that you can't share files or your printer between the virtual and real computer at the same time. You will be prompted to uninstall the printer if you try to install it on both machines. You can put files on external media to share them. Other virtual computer programs are Parallels and VMWare. However, you need a licensed version of the older Windows OS to use any of the other alternatives.
I hope this helps.
Microtek... • Answered on Aug 18, 2011
hi
according to the specs on this item, it is compatible to Windows 95/98/Me
Winodws XP drivers not available for this item.
see link, http://support.microtek.com/static/smv6upl.html
Microtek... • Answered on Nov 12, 2010
In normal circumstances it is after.
Microtek... • Answered on May 17, 2009
i want to the download the installer of microtek scanner 3880 scanner please anybody could give me this.
Microtek... • Answered on Mar 29, 2009
I found it here.. and there .. http://www.opendrivers.com/driver/233289/microtek-scanmaker-series-scanwizard-5-v6.11-windows-98-me-2000-xp-free-download.html http://kmkm.dk/scanner/MicroTek/33289/Microtek-ScanMaker-Series-ScanWizard-5-v6.11-Windows-98-ME-2000-XP.html
Microtek... • Answered on Apr 24, 2008
Google driver for Scanmaker 3800
Microtek... • Answered on Nov 20, 2017
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
Microtek... • Answered on Nov 19, 2017
Firstly ensure you what bit of your windows 7 like 32bit or 64bit. Then try it according to your bit. thanks
Microtek... • Answered on Nov 05, 2012
Microtek ScanMaker V6UPL Flatbed Scanner Logo
8 questions posted
Top Microtek Office Equipment & Supplies Experts
Resolution IT Dubai
Resolution IT Dubai
Fernando Torres
Fernando Torres
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ScanMaker Microtek
  • ScanMaker Microtek
Most Popular Question
computer dont detect
  • Office Equipment & Supplies
