20 Most Recent
Olympus Camedia D540 3.2 Megapixel: P-10 Digital Photo Printer Questions & Answers
My computer crashed and lost all pictures. I have
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
After installing my ditgital camera with my ubs cord to my camera and plugging
make sure that the camera is connected to the pc, check for the message in the camera display, say yes to connect to the pc and check if it+s been found by the computer as a drive if donĀ“t you have a problem with the camera. if it appers them the problem is in the camedia you need to go there and tell him that u are using usb port.
I have a P-10 digital
Click here for the windows drivers.
http://www.olympusamerica.com/cpg_section/software_results.asp?id=950&os=w
and then
read this article about compatibility with your windows 7 system.
please note that your photo printer is not compatible with 64 bit systems.
Good luck.
I have purchased from Ebay
After looking at the manufacturer's website I can see that the printer is only supported through XP. Do not despair however! You can still run the printer through a virtual machine using Windows XP Mode. A great tutorial is put out by Microsoft that explains how to use this feature in Windows 7. You can find it here:
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
I hope this helps! If it does, please give it a thumbs up!
Print puctrues on my computer
Open the picture you want to print in your favorite image editing or picture organizing software and click the printer icon in it's toolbar or go to File->Print. If your printer is properly setup the picture should print.
