20 Most Recent Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING Questions & Answers
2answers
Order number 091229-003792. Wireless connection
Need more details.Theres no need for any special installation or activation. A set of clear, accurate, turn-by-turn voice instructions and crystal-clear 3D graphics will help you to get where you need to go. The units simple design allows you to take the TomTom Go 700 with you from car to car quickly and easily. All the newest TeleAtlas maps are now installed on a 2.5 GB hard drive as one seamless map, allowing you to find your way to any address across all of the United States and Canada. The TomTom Go 700 is USB 2.0-compatible for faster data transfers to and from your PC. Meanwhile, the units Bluetooth receiver allows you to download real-time TomTom Plus services through the internet connection on your Bluetooth phone anytime and anywhere. TomTom Plus gives you the real-time information you want on traffic congestion and weather conditions, plus extra downloads such as detailed city maps, additional voices, points of interest, and more. Note that some TomTom Plus services require a subscription fee. Also, TomTom Plus services require a GPRS ready device equipped with Bluetooth and a GPRS subscription with your mobile operator. the TomTom700 in action Whats in the Box TomTom Go 700 portable car navigator, carry case, screen cloth, installation CD, AC adapter, cigarette lighter cable, USB 2.0 data cable, installation poster, quick start guide, product code card, TomTom GO accessory leaflet, and component parts of a suction-mount cradle. Personal Review:
12/16/2016 7:57:41 AM • Tomtom GO 700... • Answered on Dec 16, 2016
2answers
I have a Kicker 2500.1 monoblock amp. I am going
make sure that you get dual 2 ohm subs. to get a 1 ohm load, wire each sub in a series. that means the positive from one coil, connected to the negative of the opposite coil. then the other two leads will be your active speaker wires. that will give you a 4 ohm load for each sub. once all 4 are wired like this, you simply take all of the positive wires that you have left, and combine them at the amp. do the same with all of the negative wires. that will give you 1 ohm. just be extra careful to make sure every sub is wired exactly the same, otherwise your sound quality will be greatly reduced.
also, 2500 watts isnt as much power as these subs will take if wired together. it will still sound awesome, but I reccommend turning the level on your amp up just until you hear a bit of distortion, then back it off a hair. being slightly underpowered will cause you to have some distortion in your bass. playing distorted notes builds up alot of heat in the voice coils, and these subs are VERY sensitive to overheating.
4/19/2013 10:24:24 AM • Tomtom GO 700... • Answered on Apr 19, 2013
Hi. my amplifier supplies 70watt
You can try bridging the amp but you need to know how low of an ohm load your amp can safely handle. Most amps are either 2 ohm or 4 ohm stable.
2/25/2010 6:07:38 PM • Tomtom GO 700... • Answered on Feb 25, 2010
I want to add 18
add the rms power of the existing speakers, and the sub, then subtract this from the amp power rating (rms again) - at the rated impedance, and see if it is more or less than the amp output!
And the banana posts, subs are MONO and only use one channel from the amp! You need an rca to twin phono cable, then cut one of the phono (red & white) plugs off, connect the "screen" to one banana post and the centre wire to the other one.
1/13/2010 10:31:35 PM • Tomtom GO 700... • Answered on Jan 13, 2010
I have a kicker 2500.1 monoblock amp and 2 15' l7
Yes, but make "jumpers" of the SAME GAGE wiring to the each sub in series - BEFORE you go to the amp connections. Good Luck!
1/2/2010 3:27:51 AM • Tomtom GO 700... • Answered on Jan 02, 2010
Can i connect two pairs of inceiling speakers on
Sure, just split at the source.
10/9/2009 5:07:57 PM • Tomtom GO 700... • Answered on Oct 09, 2009
2 amps, 1 signal, will one work if the other doesn't?
You will have to have power to the first amp in the chain for sure so that the output signal will be there. Without power, there will be no signal.
9/29/2009 7:22:59 PM • Tomtom GO 700... • Answered on Sep 29, 2009
TOM TOM ONE GO GPS
remove the tomtom from the power source get a small paper clip and on the underside of the tomtom you will see a small pin hole it syas resetthe hole is where it looks like a sd card or something goes (but nothing goes there)
push that little reset button (in the hole) with the paper clip
hold it down for atleast 3 secs
then power the unit on give it a second itl be fine
remeber this happens a lot so keep that paper clip handy i keep it in my car all the time
hope i helped you
8/6/2009 3:11:55 AM • Tomtom GO 700... • Answered on Aug 06, 2009
Please help
I don't think you can do that if your system was not designed for the additional speakers and a subwoofer. Your system is not a Home Theater surround sound system.
You could add the additional speakers by splicing the speaker wires but I wouldn't recommend it and it would not work like a true surround sound system.
7/22/2009 10:26:40 PM • Tomtom GO 700... • Answered on Jul 22, 2009
Show me how to install 2 amps
6/3/2009 7:40:53 AM • Tomtom GO 700... • Answered on Jun 03, 2009
TOMTOM GO NOT SWITCHING ON
Hit reset button.
How old is the GPS?
Please give model and serial number to:
[email protected]
5/11/2009 2:57:16 PM • Tomtom GO 700... • Answered on May 11, 2009
Connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
4/29/2009 1:02:55 AM • Tomtom GO 700... • Answered on Apr 29, 2009
2answers
Deleted TomTom 720 fuel station icons
Try this guide it should do the trick:
http://www.tomtom.com/support/solution.php?GID=1&PID=1682&SID=0&CID=217-219&Language=1&query=gas+stations&FID=7277
If that doesn't work, just try downloading all the maps and installing them from scratch.
7/29/2008 3:11:58 PM • Tomtom GO 700... • Answered on Jul 29, 2008
Your best bet is to reinstall the maps, from scratch. This will ensure that all the maps are included.
This guide should help you out:
http://www.tomtom.com/support/solution.php?GID=1&PID=1682&CID=224-225&Language=1
7/27/2008 3:56:28 PM • Tomtom GO 700... • Answered on Jul 27, 2008
Wiring for running 4 speakers from amplifier
I asked about wiring up 4 speakers from oe amplifier....not about Tom Tom?
It does not inspire me with confidence in your abilities if you get confused between customers and their questions, so I will look elsewhere for answers.
Thanks anyway
7/4/2008 9:07:13 AM • Tomtom GO 700... • Answered on Jul 04, 2008
Amp stereo hook ups
You need to run RCA cables from the RCA output jacks on the back of the Sony to the input RCA jacks of the Jensen amp. Then you need to run a wire that connects to the blue wire of the wiring harness on the sony to the "remote" or "turn on" terminal of the jensen. That is the wire that turns the amp on when the radio is turned on. It should be on the power wire terminal of the jensen along with the +B (positive) and the GND (ground) terminals. Those are the only ones that go from the Sony to the Jensen. You also need to have the speakers connected to the speaker jacks of the amplifier, and the power wires connected to the power terminal of the amp. The positive power wire needs to go to the positive battery terminal and the ground should be connected to the chassis of the car close to the amplifier. make sure the ground is connected to a clean bare metal part to make sure it is good.
Thats all, but you also need the proper guage wire and make sure no bare wire is exposed to any metal areas or the chassis of the car. You can get all of those things at anyplace that installs car audio. They can tell you the proper guage wire and they have the RCA cables to.
If you are not experienced at this type of installation you really would be better off lettng a professioanl do it for you. It is easy to wire something wrong and damage the amp and/or the receiver.
The wires also need to be run in a place that they will not be damaged and are out of the way.
Ihope this helps you, and please be careful. Help is here if you need it.
If you found this information to be helpful a rating of "FixYa" would be appreciated. It is the only reward we get for the free help we offer.
Thanks,
Dave
6/28/2008 4:08:32 AM • Tomtom GO 700... • Answered on Jun 28, 2008
2answers
Manual for AlpineCDA9825
I tried downloading the manuals for a CDA9817, and found the procedures to be very similar, and was able to program mine with only slight differences, other than features that were different.
3/7/2008 7:06:31 AM • Tomtom GO 700... • Answered on Mar 07, 2008
Speaker wiring
No degradation. The smaller the ohm, the better the signal ( least resistance ). You and your system should be fine.
10/24/2007 7:42:59 AM • Tomtom GO 700... • Answered on Oct 24, 2007
Connecting speakers
I have never heard of this brand of amplifier.. but NEVER hook up unequal ohm loads to a amplifier. the only way i could think to do it would be to hook up 1 of each sub on each side... what way you are spreading out the ohm load equally on both sides but again if you dont do your math and you run too low of a ohm load you WILL smoke that amp..
8/21/2007 4:53:59 AM • Tomtom GO 700... • Answered on Aug 21, 2007
Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING Logo
23 questions posted
Top Tomtom Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Tomtom Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tomtom Car Audio & Video
Most Popular Question
deleted tomtom 720 fuel station icons
  • Car Audio & Video
