20 Most Recent DFI AK75-EC Motherboard Questions & Answers
To reset the BIOS back to the default settings and you cannot locate the reset jumper, just remove the BIOS battery for approx. 30 mins.
This will discharge the battery voltage in the BIOS, then insert the BIOS battery back and you can go into the BIOS configuration and set the Date and Time etc.
DFI AK75-EC... | Answered on Jan 26, 2011
http://www.gamesfree.me/games/tags/dfi/
DFI Computers &... | Answered on May 26, 2014
change power buton or reinstal windows.
DFI Computers &... | Answered on Feb 18, 2014
use norton
DFI Computers &... | Answered on Nov 11, 2013
That will be a very big blob of goo! Or a very large and wobbly hacker.
DFI Computers &... | Answered on Aug 05, 2013
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HERE ARE SAME READING TO HELP YOU TROUBLESHOOT THE PROBLEM.
DFI Computers &... | Answered on Aug 02, 2013
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
DFI Computers &... | Answered on Jun 30, 2008
It's all down to what exactly it is you want it to do! The 'Air' is a lighter weight unit with simpler parts fitted inside as it's designed more for general purpose light usage and to be easier to carry around with you. The Pro is heavier and has higher level parts fitted inside It is designed for heavier use, closer to how a desktop computer would work.
Computers &... | Answered 14 hours ago
DFI AK75-EC Motherboard Logo
3 questions posted
Top DFI Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Carlo Barzo
Carlo Barzo
Roy May
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • DFI Computers & Internet
Most Popular Question
need reset bios password cannot reset
  • Computers & Internet
