20 Most Recent Packard Bell iMedia 6826 (P481000502) PC Desktop Questions & Answers
You don't have a display problem, you have a hard drive problem. It is probably a file system corruption. Insert the Windows XP install disk into your CD drive and boot to it. At the first setup screen, press R to repair windows from the recovery console. Once the recovery console loads, type chkdsk /r and then press Enter. Once this finishes, remove the CD and reboot. With any luck, you will be able to boot successfully, if not, come back and give details about what happens.
Packard Bell... • Answered on Mar 06, 2017
Look on the back of the pc. There should be a speaker socket (usually Green in coilour) plug the speakers in to there. Alternativly there may be a headphone socket on the front. Use that.
Packard Bell... • Answered on Aug 02, 2016
if you have a 3 plug ribbon, plug it into the new hard drive and plug in a power supply plug
Packard Bell... • Answered on Feb 10, 2015
PROBERLY ELECTRICAL.CHECK ALL ELECTRICAL WIRES CAN BE A LOOSE WIRE.OR A BAD CONNECTION SOMEWERE.
Packard Bell... • Answered on Aug 26, 2013
take out the cell found on r motherbord& place it after exacly 4 minutes restart it i often have this problem,, plz vote 4 me
Packard Bell... • Answered on Jun 08, 2013
What your computer is telling you is that you're plugging a USB 2.0 device into a USB 1.0 port. The only way to tell would be using a process of elimination but for the most part you're almost always going to have a uniform set of ports meaning all USB 1.0 or USB 2.0. I wouldn't worry about this at all, the difference is minimal for speed and it won't make your PC faster... just the device you're plugging in.
Packard Bell... • Answered on Apr 15, 2013
click on START-SETTINGS-CONTROL PANEL- DOUBLE CLICK "SYSTEM"- SELECT THE "HARDWARE" TAB AT THE TOP- CLICK THE DEVICE MANAGER BUTTON-
NOTE: Any entries found here with a YELLOW ! OR ? are drivers the are corrupt, wrong or installed incorrectly. They will need to be uninstalled and new updated drivers downloaded from the internet installed in thier place.
Regards..
Packard Bell... • Answered on Mar 21, 2013
It's a computer, there are no FAX instructions. If you have a modem in there, you can run FAX software and the problem is reduced to understanding the FAX software. Check out softpedia.com and Cnet for some examples of free FAX software....
Packard Bell... • Answered on Feb 16, 2013
Does it turn on for a few seconds and shut down? That sounds like a PSU failure. Try reseating the Memory mods, or remove 1 then the other, swap. Replace the CMOS battery. When you push the on/off button, it stays powered up? But does not boot? HDD spins? LED's blink?
Packard Bell... • Answered on Dec 25, 2012
modem codec is incompatible with your hardware
Packard Bell... • Answered on Nov 27, 2012
What brand is your SD card? It maybe be seeing it as you may not the proper card reader driver for your PC. Try reloading the drivers and see if that helps
Packard Bell... • Answered on Oct 21, 2012
First, update your java runtime environment software to the latest version for here:http://www.java.com/en/download/manual.jspThen update your Adobe flash player software to the latest version.For Internet Explorer you need this update:http://majorgeeks.com/Adobe_Flash_Player_for_Internet_Explorer_d5163.htmlFor Firefox, Netscape, Opera and Chrome use this update:http://majorgeeks.com/Adobe_Flash_Player_for_Firefox_Mozilla_Netscape_Opera_d7806.htmlIf that doesn't fix it you might have some viruses and malware. Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
Packard Bell... • Answered on Sep 05, 2012
I would suggest going to the Packard Bell Support web site then select your country followed by selecting your model of computer which will then give you access to any available documentation to help you with upgrading memory etc.
Packard Bell... • Answered on Jan 13, 2012
Hello and thanks for using Fixya ...This issue you described it can have several different causes...first it can be a virus causing something and as a prevention the computer is turning itself down to avoid damages...and in this case you should be able to fix it by reinstalling the operation system from scratch ..using a bootable disk with the OS on ..and formatting the hard drive C partition during the installation to get rid of eventual bugs..Ifr after this operation the computer is still doing the same ..it indicates that the cause it is of a physical damage or compatibility issue..Chech the ram memory not to be damaged...and do this by uing the computer with only one module at the time ..and let it work untill it does the same or not...Keep the modules that do not cause the shut down ..and replace the others..If the shuting down is actually a restart ..and it does it after showing the blue screen error ..than the cause is almost for sure the Ram memory units...and even if they are not damaged...the cause can be just a compatibility issue ..Check on the web for the specs of the motherboard...and see what they say about the Ram memory speed amd maximum value ..For example ..if your computer was build to use Ram memory up to 533 mhz or 667 ...and you use same DDr2 modules but the speed is up to 800 Mhz ..it is possibleto work a while and after that to start making problems on start up ..and shuting down suddenly with no warning ..and work fine if you restart it ..but ...making the same sympthoms after a while ..(usually the interval is smaller after it is warming up ..)In this case you need to buy replacement and whith the exact specs like the ones in the manual..Also do not use the maximum value supported..but for example if you have 2 slots suporting 1 G each ...use one with 1G and one with 512 M and it will work for sure..another cause can be a CPU related ...if in BIOS settings it was by mistake or as a protection ..set a maximum allowed teperature...This will cause automatic shut down when the cpu gets to that temperature...The best way to avoid this ..is to get into BIOS ..and engage the optimal factory settings from the function key indicated by your Bios edition ..and after that use the F10 key to save the settings and exit..This will prevent the shut down if it is related with a strange setting made in bios..If after all these the issue is still present ..the only thing that can be damaged is the motherboard...and it is probably something sensitive on temperature..and it works fine untill getting to the critical value..This wil aply also to the power source ...If the fan is not working or it is dirty and do not do the job ...the power source can actually shut itself down as a protection when it gets to a certain temp.value..have a nice day ...and I hope this will help ..
Packard Bell... • Answered on Dec 14, 2011
Packard Bell iMedia 6826 (P481000502) PC Desktop Logo
Popular Tags
142 questions posted
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Abhinandan  Patil
Abhinandan Patil
Jax Planet
Jax Planet
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iMedia Packard Bell
  • iMedia Packard Bell
Most Popular Question
pc wont boot up screen stuck packard
  • Computers & Internet
