20 Most Recent
Peripheral Enhancements EDGE Tech Corp Whelen Edge Power Supply 2X6 (WH2X6) Power Supply Questions & Answers
Ive got a whelen edge
Exactly what kind of switch are you using? If it has more than 2 connections, you may have it wired to 2 connectors that are always connected together. If it has more than 2 connections, try disconnecting all the wires and going over it with a continuity tester or ohm meter and check the function of each connection. If your switch has only has 2 connectors, they may be welded together internally in which case it is defective. Again, use an ohm meter or continuity tester and check it out.
Good luck,
Jeff Mc.
Thers 4 wires to connect 1 red 1 black 1 white and
Well, if there are no color lights on this strobe effect, a fairly standard color code for AC is Black is HOT White is Neutral, no insulation is ground and Red would power your strobe ( I Think )., I would hate to misinform you. Is this an AC powered strobe? Like when you wire up a ceiling fan you have the same color code. I'm sorry I can't help you further, and messing with live AC can be unsettling.
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
