20 Most Recent Roland Boss Micro BR Multi Track Recorder Questions & Answers
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied? Where you convert the file? BR or computer? What software you use to convert?
9/3/2015 3:51:25 AM • Roland Boss... • Answered on Sep 03, 2015
I am hearing a buzz when i turn on the mic. What's the solution, can you let me know please?
Buzz is almost always a grounding. Check the soldering. If you are not comfortable with that get a known working mic and cord and try that out.
11/30/2014 1:47:19 AM • Roland Boss... • Answered on Nov 30, 2014
I plugged what i assumed
This was probably supposed to have a 5 volt power adapter... you burned up either:
1. Regulator
2. Circuit trace on the board
3. Protection diode
4. resistor ahead of the regulator.
Repair should not be too bad if they know exactly what you had connected, Make sure to use a competent shop.
5/7/2011 5:37:55 AM • Roland Boss... • Answered on May 07, 2011
2answers
When I power my Roland D20 up, all I get is bars
Hello. Hello. Generally the upper LCD display of bars is an indication that the internal battery is on it's way out and needs to be replaced.
In case you do not have the owner manuals, they can be downloaded from this address - enjoy: http://soundprogramming.net/manuals/Roland_D-20_Manual.pdf
3/28/2024 1:20:25 PM • Roland Music • Answered on Mar 28, 2024
I have a ROLAND BK5 keyboard instrument that has no sound out of speakers or headphones but it has new ribbon cables all components are working just fine except the sound
I wonder why the ribbon cables have been replaced as they do not fail. Check the keys actuate the contacts properly.
11/1/2023 7:57:00 AM • Roland Music • Answered on Nov 01, 2023
2answers
Damper pedal piano doesn't keep the tone properly
I can't! In my opinion, no. Start drift boss customize your car by choosing different colors and patterns.
10/31/2023 1:49:23 PM • Roland Music • Answered on Oct 31, 2023
ROLAND G70 . I HAVE LOST THE VISUAL OF THE MIDI
4/17/2023 4:19:13 PM • Roland Music • Answered on Apr 17, 2023
2answers
My Roland FP4 piano has suddenly ceased to power on. Is this fixable?
most likely we dont have crystal balls --need to have diagnosed for problem
4/10/2023 12:49:18 PM • Roland Music • Answered on Apr 10, 2023
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM • Roland Music • Answered on Jan 05, 2023
Roland cube 80XL, making weird sound when it's on, nothing is plugged in, all controls down to 0
I am also using IOS and Android. So how can I improve some features? The black screen helps you relax when using the computer too much.
12/22/2022 6:43:06 AM • Roland Music • Answered on Dec 22, 2022
Roland Octapad SPD-30 dead.
Question edited for a bit more clarity. Video that might help https://www.google.com/search?q=Roland+octapad+spd30+dead Owners Manuals only. https://www.google.com/search?q=roland+octapad+spd30+service+manual ..
12/19/2022 1:50:50 AM • Roland Music • Answered on Dec 19, 2022
2answers
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information. I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM • Roland Music • Answered on Nov 17, 2022
My Roland KR 4500 powers up to a blank screen, no button led. No key sound.Power led is lit. Amp and speakers work fine with external sound input.
Sounds like a blown motherboard to me. It needs to go to the shop.
11/17/2022 9:46:44 AM • Roland Music • Answered on Nov 17, 2022
Where can I buy a motherboard for a Roland Fantom X7 OTHER than Roland?
I need fantom x6 motherboard!!! My whatsapp no +91_9760504606
9/22/2022 4:58:55 AM • Roland Music • Answered on Sep 22, 2022
2answers
MY Roland Handsonic's digital display is gone
Hell,
there is no display on your Roland Handsonic because the screen inverter or screen board panel is faulty. This has to be replaced for you to see your digital display again.
So its either you use it like that without the display or you take it to a repairer for fixing.
Take care.
7/11/2022 8:54:01 AM • Roland Music • Answered on Jul 11, 2022
Will my Roland rd100 sound good with rs501 clarifier
This depends entirely on what you personally define as 'Good'. The only real answer to this is try it, listen to it and decide for yourself.
4/24/2022 3:33:09 PM • Roland Music • Answered on Apr 24, 2022
Roland Boss Micro BR Multi Track Recorder Logo
4 questions posted
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
transfer track data computer
  • Music
