20 Most Recent Yamaha DGX630 - Digital Piano Questions & Answers
dgx screws are so many..u have to open the speaker covers there are other screws inside...which u can only access by oppening the speaker back cover...you will also have to open the silver screws..all of the behind the cover..all this u r doing when you have separated it from the stand. place it on a mattress in need be to avoid accoustic wear.
Yamaha DGX630 -... | Answered on Oct 17, 2014
Best advice I can give: Don't. take it to a music shop to let them do it under warranty.
I can appreciate wanting to do it yourself, but (and PLEASE don't take this the wrong way) if you're inexperienced enough to need assistance opening the case, then maybe it's best to let someone else do it.
Yamaha DGX630 -... | Answered on Sep 26, 2014
Dear Joseph,
I had similar problem with my DGX620. In my case the display sometimes got blue and sometimes worked fine. The cause was a bad contact of the display flat cable.
I opened the DGX620 and then I cut a small piece of plastic film (35mm negative) with exactly the same width of the flat, disconnect the flat cable and then reconnected it using the film on the other side (non contact side) to increase the pressure and guarantee a good contact. No more problems from nov-2012 till now.
Good luck !
Paulo de Tarso (Brazil)
Yamaha DGX630 -... | Answered on Jan 13, 2014
Perhaps the performance assistant technology is turned on.
Press the [PERFORMANCE ASSISTANT] button to turn it off.
Yamaha DGX630 -... | Answered on Jan 14, 2013
Do the lights come on?
Have you tried the headphone output as well as the line output(s)?
Is the volume turned up?
Do you have it plugged in with the original Yamaha AC adaptor?
https://usa.yamaha.com/support/manuals/index.html?l=en&c=keyboards&k=DGX505
Owners manual in the link.
Yamaha Music | Answered on Nov 04, 2019
seems to be a standard acoustic setup to me. If it doesn't have all the string pins in it, you'll need to get some. you simply pull out the pin, put the string in, then wind it up on the machine heads (tuners) On this one you may need to put the strings through from the inside, I'm not sure about this particular model. I like a double wrap to start on the bass strings, but that's a choice I make. You could go with nylon strings, get ball end, they're easier to use than plain. It takes a bit of know how to do plain, thy have to be wrapped just right on the pins.
Yamaha Music | Answered on Nov 02, 2019
You may find one if you google it.
Yamaha Music | Answered on Oct 27, 2019
Hi
If you are talking about cleaning the rubber contacts I wouldn't bother. Once they start to fail then it is best to replace them. You can do this either for the octave giving problems or best to replace complete set. Main part is VY84670R your piano has 6 octaves of these. with a shorter part at either end.
Yamaha Music | Answered on Oct 24, 2019
Yes you may use it as stand alone piano. Usually everytime you will power ON any yamaha psr model piano will appear as default voice.
Yamaha Music | Answered on Oct 19, 2019
try www.amazon.com,
Yamaha Music | Answered on Oct 06, 2019
This should help you trace the wires
Yamaha Music | Answered on Sep 27, 2019
Hi
the blue screen with lines is normally as a result of the ribbon cable which has contacts on failing.
The remedy is normally to replace the simple the screen assembly the parts for this are around £300 but there would be significant labour to add to this.
i would suggest talking to a local Yamaha technician
Becketts Music Ltd
Yamaha Music | Answered on Sep 17, 2019
Yamaha DGX630 - Digital Piano Logo
6 questions posted
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
open case repair power supply
  • Music
