20 Most Recent Soyo Onyx SYTPT4227AB 42 in. LCD TV Questions & Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Soyo Onyx... | Answered on Feb 17, 2018
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Soyo Onyx... | Answered on Nov 02, 2015
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Soyo Onyx... | Answered on Jul 05, 2015
take the back off and get to the power supply most likely you will find some bad capacitors in it they will probaly have the tops of the caps bulgeing.
Soyo Onyx... | Answered on Feb 10, 2012
Good day!!!
Sorry for the late response because my internet connections got problem hope you understand..
OK,First thing I need to know if the board on the picture in the forum is the original board of your TV or it is the board you purchase..
If that is the board you purchase I think that board is the exact replacement however it different on the version of said board..so that the TV works fine but the remote is not function..Or the IR is bad..
try to see the version on the original board to the new purchase board if the same..
check the encircle part of main board need to compare..
If they are the same the problem I see is the IR sensor try to clean it first including the glass protector before you replace it..
But if the problem is different version no choice you need to replace the board or contact the store where you buy it and ask for replacement..
Just keep on touch to fix the problem..
Hope it helps
thank you
Rossiel
Soyo Onyx... | Answered on Feb 03, 2012
I recently repaired 2 LCDs that would not imidiatly turn on when the power button was pressed. It took the first one 5-10 cycles before it would start, and the little one took about a half hour. I removed the back and found that a few components were bad on the inverter portion of the board and replaced them with corrisponding parts from a local electornics store and they both started first try everytime. If you have the tinkering spirit and for the price of a soldering station some desolder braid and some solder you could fix your problem today.
Just make sure it is unplugged!
Soyo Onyx... | Answered on Apr 18, 2011
Hi.
It appears that your are having a tube failure issue.
Either that, or you have a capacitor problem.
Both can act like that, but as a rule the tube acts more like that when it fails than the other parts of the tv.
The tubes are replaceable, and are available from Fry's and BestBuy.
If it winds up that it is the capacitors instead, then I would take the tv to either Fry's, BestBuy, or RadioShack.
These companies have specially trained techs for just that repair, as it takes special skills to deal with the voltage and power that capacitors can hold in them.
I hope that this helps you out some, and good luck!
Soyo Onyx... | Answered on Mar 13, 2011
Off brand televisions have problems with the engineering behind their components. You will need to look for popped or buldged capacitors on the power supply mainly! Also look for any burnt resistors as these also over heat and will pop capacitors.
Please rate if this was helpful!
Soyo Onyx... | Answered on Mar 03, 2011
The power supply board is the cause.The board,where the power a/c cord plug in to it.Replaced the power supply board,will solve this problem.If its under warranty have it service.
Soyo Onyx... | Answered on Jan 19, 2011
Power LED light indication blinkings or completely dead?Yes,than the power supply board is the causes.That the board,where the power a/c cord plug in to it.Take the aparts,replaced the power supply board,will sold this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Soyo Onyx... | Answered on Nov 20, 2010
Tv was working fine and all of a sudden it show off and will not work at all. Please Help
Soyo Onyx... | Answered on Oct 23, 2010
Soyo Onyx SYTPT4227AB 42 in. LCD TV Logo
Popular Tags
30 questions posted
Top Soyo Televison & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Televison & Video
Most Popular Question
tv says no channel list put list back
  • Televison & Video
