20 Most Recent
Dynex DX-L32-10A 32" LCD HDTV Questions & Answers
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Dynex DX-L32-10A...
Answered
on Jan 11, 2017
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dynex DX-L32-10A...
Answered
on Aug 14, 2015
unplug your TV for 30 seconds and then plug it back in. Or just follow the directions on screen on how to use the volume control buttons and that should help.
Dynex DX-L32-10A...
Answered
on Jan 29, 2015
It would be best to call a TV installation company to do this for you.
Dynex DX-L32-10A...
Answered
on Aug 03, 2014
Please provide more details. The problem post you have placed here is difficult to understand. What is the problem you faces with this TV, when you switch it ON?
Dynex DX-L32-10A...
Answered
on Jul 28, 2014
Make sure the signal cable for the input you are using is tight. Possibly try a different cable. Especially if you are using the Red Green Blue component cables. Make sure the issue is across all inputs. If so, try adjusting settings for tint. if that doesn't help you may need to replace the TV.
Dynex DX-L32-10A...
Answered
on Apr 10, 2014
Have you tried to reset the remote? To do so, press all the buttons at once & hold for a few seconds. You can then re-program your remote to the TV. Also, you can try to power cycle the TV by unplugging it, leaving it unplugged for a few minutes, and plugging it back in & restoring settings back to factory defaults. This should resolve the issue.
Dynex DX-L32-10A...
Answered
on Feb 24, 2014
I would recommend pursuing repair options with a licensed service technician, as most likely this is caused by a hardware malfunction. Bear in mind, repairs may not be cost effective, and therefore, may be cheaper to pursue replacement TV options.
Dynex DX-L32-10A...
Answered
on Oct 30, 2013
Try to unplug the set from power for a while and see if it reboots.
Dynex DX-L32-10A...
Answered
on Nov 05, 2012
I see so many here with no sound/no picture issues: ISSUES: 1. IF sound main fuse/s are good. 2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc. 3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down the problem. 4. Be safe and if you do not know what you are doing don't open the set. Answers to issues: 1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason. 2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not. Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom. What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail. 3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not. 4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo.
Dynex DX-L32-10A...
Answered
on Nov 05, 2012
On the right hand side there should be a panel of buttons. One is marked "Input". That should change your video mode.Manual available,
click here.
Dynex DX-L32-10A...
Answered
on Oct 21, 2012
