20 Most Recent
ip-adress.com Questions & Answers
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit
IP-details.com and get the IP.
My ip adress is gone
Normally IP Address is assigned by your router which then also provides gateway and dns settings. On the IP address screen, select Obtain automatically for both IP and DNS.
If this does not solve your problem, please explain fully what the problem is.
Find activation code
I don't understand the question, find the activation code to what?
What does that have to do with problems with ip-address.com websites?
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
What services does your web agency in Linkoping offer?
We offer a variety of services, including web design https://webbson.se/linkoping web development, e-commerce solutions, mobile application development, digital marketing and search engine optimization (SEO). Our goal is to help companies and organizations in Link?ping with everything related to their online presence.
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
