20 Most Recent Russell Hobbs RHM1709 Microwave Oven Questions & Answers
No power what-so-ever to microwave
make this test and fix it. GOD BLESS YOU
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
11/2/2013 12:36:27 PM • Russell Hobbs... • Answered on Nov 02, 2013
Russel Hobbs Microwave door broken glass
2/1/2023 5:14:24 PM • Russell Hobbs... • Answered on Feb 01, 2023
Russell Hobbs RHEM30G. looking for a manual please?
Question edited for clarity, spelling and typos. Question moved from Cameras Category. 72 page manual is here
Russell hobbs RHEM30G Manuals - ManualsLib
https://www.manualslib.com > ... > Microwave Oven Manuals and User Guides for Russell Hobbs RHEM30G. We have 1 Russell Hobbs RHEM30G manual available for free PDF download: Instructions And Warranty ... ..
12/22/2022 6:07:40 PM • Russell Hobbs... • Answered on Dec 22, 2022
How do I replace the bulb on a Russell Hobbs rhm3003b microwave
Remove the outer cover to gain access.
3/13/2021 5:56:22 PM • Russell Hobbs... • Answered on Mar 13, 2021
Download manual Russel Hobbs RHMM20 microwave
https://en.russellhobbs.com/user-manuals Looks like they do not have microwaves on here Contact the manufacturer at your country-appropriate address here https://en.russellhobbs.com/contact-us
11/12/2019 9:18:47 PM • Russell Hobbs... • Answered on Nov 12, 2019
Russell Hobbs 2060b microwave I bought it as an 800 watt on the back it says 750 to 800?
Wattage may very with the power used for microwave.
3/4/2019 9:40:34 AM • Russell Hobbs... • Answered on Mar 04, 2019
Broken glass on full size microwave door Russell hobbs model RHEM30L
so order a replacement fixya doesnt sell products
11/25/2018 2:37:57 PM • Russell Hobbs... • Answered on Nov 25, 2018
Microwave will not heat food up since i used defrosting mode.
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
5/10/2018 4:39:10 PM • Russell Hobbs... • Answered on May 10, 2018
Russell Hobbs RHM1709 Microwave Oven Logo
Popular Tags
6 questions posted
Top Russell Hobbs Microwave Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Russell Hobbs Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Russell Hobbs Microwave Ovens
Most Popular Question
no power ever microwave
  • Microwave Ovens
